A/C Problem
Old Aug 15, 2010 | 06:05 PM
2010 TL Tech's Avatar
A/C Problem
Leased my 2010 TL Tech in March. This summer here in NY has been very hot. I noticed that the A/C was not that cold. Put an instant read thermometer in the center vent, 48 degrees. Would not go any further . Tried everything auto, off auto nothing. The recirculation button lights up but when you press the button to turn off or on, no difference in fan speed nor do you hear the door closing. However when you have the a/c off and in the vent mode it works. crazy. My 06 TSX has none of these issues. a/c goes down to 40 easily. Took car to dealer and of course they say it is normal. Thats total BS and i told them that, Took the TL to my own mechanic. He evacuated the system and recharged. No difference. Went to another Acura dealer. The a/c in his TL went down to 40-42 degrees. They will check the a/c. Hopefully they will find the problem. The service advisor said there is a valve that allows hot water into the heater core and maybe it is not closed all the way. We will find out.
Old Aug 18, 2010 | 05:26 PM
Motorista's Avatar
That's possible but relatively easy to verify: start the fan with AC off, auto off and the temperature on the coldest possible setting on a cool evening night and check the temperature of the air coming out of the vents after at least five minutes of operation: if it's coming out higher than the outside temperature a bit of hot water is seeping throuhg the heater matrix.
Old Aug 18, 2010 | 06:03 PM
vinnier6's Avatar
48 degree air isnt cold enough?? whats it supposed to be?
Old Aug 18, 2010 | 08:20 PM
Kingmeow's Avatar
48 is definitely not enough. Usually in the low 40's close to 40. Take an infared temp gun to it and you'll be amazed at how cold the air coming out really is.
Old Aug 19, 2010 | 04:03 PM
I will check the temperature tonite like you said with the a/c off. The TL is going to the dealer next week. Will let you know what they find.
Old Aug 24, 2010 | 08:38 PM
So went to the dealer today for the a/c. They evacuated the system and recharged it. The a/c drops to 44 then rises to 48 then back down etc. I think it should be better but it is colder than it was. They stated that the heater control valve was working ok. Who knows if they even checked it. It's been cool here in NY. Will know bettter when the hot weather returns.
Old Aug 24, 2010 | 10:32 PM
Kingmeow's Avatar
The A/C works more efficiently when outside ambient is hot. These past days in the Northeast is horrible with temps under 70.
Wait until it's hot out (weatherman says next week) and test again.
Old Aug 25, 2010 | 09:06 AM
ss284's Avatar
You might be right that the AC system is more efficient in hot weather(provide a larger drop in temperature relative to ambient for less energy), but the hotter it is outside, the hotter the AC output will be.
Old Mar 1, 2012 | 12:53 PM
jhammer's Avatar
I have had my 2010 TL in twice for poor AC why bother with the solar sensor, I drive my 2002 Grand Cherolkee in the summer I live in NM, temps max out aroung 95 here and I hate my TL in the summer
Old Jun 12, 2012 | 03:50 PM
pimpin-tl's Avatar
See my post for a resolution on the AC problem.
https://acurazine.com/forums/4g-tl-problems-fixes-297/new-2012-c-not-cooling-well-859479/
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
