Clean PCV Valve
Old Jun 11, 2013 | 05:22 PM
WPP's Avatar
WPP
6th Gear
Clean PCV Valve
My 2010 TL has 55K miles on it and I want to clean the PCV valve. Can someone tell me where it is located?
Old Jun 11, 2013 | 07:28 PM
rebmem's Avatar
On my 2009 TL it is located on the front valve cover at the far right end right above the oil filler cap, hidden somewhat under the wire harness plastic cover. (FYI: Just to the left of the EGR valve)
It is held in by one bolt. Has 2 o-rings on it per the factory repair manual.
Old Aug 30, 2014 | 08:43 AM
antlive's Avatar
Cruiser
Can someone help me out here, I've been looking for this thing and can't find it either
Old Aug 30, 2014 | 12:42 PM
Reorge's Avatar
Item 14
http://www.acurapartsforless.com/aut...ead-cover-scat
Old Aug 30, 2014 | 03:56 PM
Tonyware's Avatar
'20 TLX SH-AWD A-Spec
I don't think the PCV valve is something that gets contaminated with carbs or anything else, easily. And at 55K miles it probably looks shiny and new. On the other hand the EGR valve and the EGR passage, under the cover of the intake manifold, probably need some car cleaner on them.
Just a thought...
Old Sep 3, 2014 | 10:07 AM
Reorge's Avatar
I changed the PVC valve on my friends 2008 Odyssey (106K miles). It had some oil on it but otherwise it was clean.
Old Sep 4, 2014 | 12:11 AM
dcmodels's Avatar
Not sure about a TL, but on most cars, the PCV is less than $10, so just replace rather than try to clean? on my RDX its almost $20, but then, its also not the typical simple design PCV, being specifically for the Turbo application.
Old Sep 6, 2014 | 07:12 PM
dip10's Avatar
what's the reason to change this? Any symptoms?
Old Mar 10, 2015 | 09:03 PM
asb32952's Avatar
It should be changed at about 80k IMO, sooner if short commutes are prevalent. If it gets dirty and doesnt vent properly, extra pressure will build up in the crankcase, which will cause oil to leak thru gaskets and rear main seal. The rear main seal is a $15 part, but the transmission needs to be removed to get to it which is prob $500 in labor.
Here is a new one for $11 shipped, although it is prob an aftermarket if it matters.
http://www.ebay.com/itm/PCV-Valve-For-Honda-17130-RCA-A02-/161616456557?_trksid=p2141725.m3641.l6368
There are discussions about seafoam, which could help if you do it right.
Preventive maintanence.
Old Mar 10, 2015 | 11:23 PM
asb32952's Avatar
OP add
rear main seal leak oil leak
to the title.
Old Mar 14, 2015 | 03:20 PM
asb32952's Avatar
The above part arrived today and is stamped "japan" on it.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
hashbrown
Feb 18, 2022 11:20 AM
Mike734
Dec 10, 2021 01:25 PM
08KBP_VA
Oct 22, 2019 01:55 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
