Center Armrest
Old Aug 1, 2012 | 09:59 AM
jgallis's Avatar
5th Gear
Center Armrest
Just bought a 2010 TL Base with 24k miles and loving it. As when I buy any car, I drove it thoroughly enough to know that there were no squeaks or rattles. Then, I found and read this forum. Then I started listening closer, then i heard some noises. Drove me nuts. Moral of the story is to check the sunglasses holder. Do not know how they got in there and they are not mine, or anybody else in my family's. No noises! I was getting ready to go find a different car.
I have a question. Does anybody know how to remove the center armrest/console cover of a 4g? I bought used and a bubble/wrinkle needs to be fixed. I have read some other threads and understand that a dealer would probably take care of it under warranty. I want a local upholsterer to do it with real leather.
Thanks for the help.
Old Aug 1, 2012 | 11:35 AM
potmilkz's Avatar
have you tried looking around the area where the center arm rest is?
usually its just held by two screws to the base...
Old Aug 1, 2012 | 11:36 AM
potmilkz's Avatar
Old Aug 1, 2012 | 06:24 PM
jgallis's Avatar
5th Gear
I have looked around and done some research. I have seen this pic. I got the two behind the rear vent cover. They do not release it, easily anyway. I think it is also fastened to the front, by the "u". Does anybody know where/how? Does it just pull apart like so many of the other parts? Thanks for the responses.
Old Aug 5, 2012 | 08:32 PM
jgallis's Avatar
5th Gear
Went ahead and had the dealer replace it, under warranty. Dealer did a good job, but I just know it is a matter of time before this happens again. The replacement has an even cheaper look than the original. Certainly not leather, as everybody knows. Need to have this done right.
Old Aug 5, 2012 | 10:33 PM
vinnier6's Avatar
we all know its not leather....
i dont know how the replacement looks cheaper then the original, it should look exactly the same....because it is....
Old Aug 6, 2012 | 02:49 AM
Edward'TLS's Avatar
6G TLX-S
Probably minor color mismatch due to the new replacement part vs. the 2-yr old car.
Old Aug 7, 2012 | 08:53 PM
jgallis's Avatar
5th Gear
newer = shinier = cheaper looking? I don't know. Just don't like it.
Old Dec 31, 2012 | 02:17 PM
Sav2010TL's Avatar
9th Gear
I have the same problem with my 2010 TL armrest. The problem is not so much with the leather but with the padding underneath. The black padding is cheap and quickly breaks down leaving the leather loose. When I took the leather off the foam just crumbles away in your hand. I am having mine replaced under warranty this week. I took pics of how it came apart. I just need to figure out how to post them.
Old Dec 31, 2012 | 02:53 PM
Sav2010TL's Avatar
9th Gear
[IMG][/IMG]
http://i1289.photobucket.com/albums/...psdf80dcfa.jpg
Old Dec 31, 2012 | 02:54 PM
Sav2010TL's Avatar
9th Gear
[IMG][/IMG]
Old Dec 31, 2012 | 02:58 PM
Sav2010TL's Avatar
9th Gear
Slide something thin between upper leather and lower plastic piece. I used a nutter knife. 2 clips in the front takes the bottom off. 6 screws hold the top leather covered piece on. Removal of entire armrest and hinge assembly not necessary to do this.
Old Dec 31, 2012 | 02:59 PM
Sav2010TL's Avatar
9th Gear
[IMG][/IMG]
Old Jan 1, 2013 | 06:00 PM
Acc-Rite's Avatar
could you take photos of where you removed your bolts from the console itself?
Old Jan 8, 2013 | 08:19 AM
Sav2010TL's Avatar
9th Gear
Sorry, my pictures were from a junk unit that Acura was throwing away, I didnt actually take it out of the car. I just took it apart. You do not need to remove it to get the leather top off from my previous pictures. I will post a pic of the bottom part of the console. It looks like 6 bolts but I'm not sure.
Old Feb 11, 2014 | 01:12 PM
acuraboriqua's Avatar
Rally Man
I have the same problem. Need more detailing to dismantel the arm rest cover. Any help email to stigers.james@gmail.com. Thanks.
Old Mar 5, 2014 | 09:21 PM
blown_m3's Avatar
I am getting my replaced for $30
Old Jul 10, 2016 | 07:53 AM
Hogan9166's Avatar
Just resurrecting this thread. Any other info on this?
The padding on mine is completely broken down from me leaning on it for the last 183K miles. I am going to drive this car as long as it will continue to drive, but I'm now leaning on hard plastic under leather and I need to fix it. Any ideas? Inexpensive replacement parts?
In the pics above, I couldn't tell how the leather is attached to the lid. Is it glued?
Thanks in advance.
Old Jul 10, 2016 | 11:50 AM
csmeance's Avatar
Thanks in advance.
Yes the leather is glued onto the plastic with the foam in the middle. If you take off the armrest any shop can do it for a great price!
Old Jul 10, 2016 | 11:54 AM
Hogan9166's Avatar
Great. Thank you.
Old Feb 22, 2017 | 11:57 PM
Christopher Michael's Avatar
toferdisobey
Here I just did this and there's a much easier way. With photos:
https://acurazine.com/forums/fourth-generation-tl-2009-2014-123/help-2010-center-armrest-removal-899991/#post15964971
vpasla1
Sep 17, 2016 07:24 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
ROWDY621
Sep 30, 2015 03:20 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
