The car will not start
Old Oct 30, 2017 | 02:31 PM
RCANTRELL's Avatar
i left my 2013 acura tl running then it shut off and it wont start now
Old Oct 30, 2017 | 02:37 PM
echodigital's Avatar
From TL to RDX
Battery?
Old Oct 30, 2017 | 02:39 PM
RCANTRELL's Avatar
It looks like there is a blinking light on the dash. I thought it might be a silent alarm.
Old Oct 30, 2017 | 03:24 PM
losiglow's Avatar
Yes, the blinking red light indicates the immobilizer is active. Does the accessories come on and the screen display the insert key error (assuming you have push-start). Or is everything more or less acting dead.
Old Feb 26, 2019 | 07:54 AM
Acuranoobb's Avatar
3rd Gear
Hi
Im having this same issue. Am getting no power and everything pretty much dead. Only horn and hazard lights work. There’s a small circular red light blinking on the dash cluster. Any clues?
Old Feb 26, 2019 | 11:13 AM
losiglow's Avatar
The small red light on the dash is the alarm indicator. Replace the battery in your key fob. Or try inserting it into the slot. That's assuming you have the Tech or Advance trim.
Old Feb 26, 2019 | 11:41 AM
Acuranoobb's Avatar
3rd Gear
Its the tech. Replaced the fob battery and inserted the key with no help. Brand new car battery too.
Old Feb 28, 2019 | 02:41 PM
Acuranoobb's Avatar
3rd Gear
TL with no power
any suggestions for a cause or issue? Dealer said it was the battery terminals but the problem is still happening
Old Mar 23, 2019 | 08:52 AM
Pless4's Avatar
No power
I watched a you tube video about jumping slot 4 and 9 on the ecu plug to reset the ABS and VSA lights on the dash when I connected the wire to those ports I shorted out everything inside the car no power everything in the engine compartment fuse box looks good any ideas about what BLEW or what fuse it might be
javamanbill
Feb 4, 2017 11:27 AM
navicolb
Nov 8, 2016 12:43 AM
berkeleysquirrel
5G TLX Problems & Fixes
Oct 10, 2016 07:18 PM
Eggplant-EX
Dec 26, 2001 10:48 AM
