The car will not start
i left my 2013 acura tl running then it shut off and it wont start now
Battery?
It looks like there is a blinking light on the dash. I thought it might be a silent alarm.
Yes, the blinking red light indicates the immobilizer is active. Does the accessories come on and the screen display the insert key error (assuming you have push-start). Or is everything more or less acting dead.
Originally Posted by losiglow
(Post 16122499)
Im having this same issue. Am getting no power and everything pretty much dead. Only horn and hazard lights work. There’s a small circular red light blinking on the dash cluster. Any clues? |
The small red light on the dash is the alarm indicator. Replace the battery in your key fob. Or try inserting it into the slot. That's assuming you have the Tech or Advance trim.
(Post 16389311)
TL with no power
any suggestions for a cause or issue? Dealer said it was the battery terminals but the problem is still happening |
No power
I watched a you tube video about jumping slot 4 and 9 on the ecu plug to reset the ABS and VSA lights on the dash when I connected the wire to those ports I shorted out everything inside the car no power everything in the engine compartment fuse box looks good any ideas about what BLEW or what fuse it might be
