A/C safety feature or glitch?
Old Jun 28, 2022 | 01:19 PM
Rhys Pieces's Avatar
I own a 2012 TL automatic w/Tech pkg. Waiting at a light on afternoons over 100F, my A/C compressor will disengage until I get moving again and things are good until the next red light. Is this because the system is designed to protect itself from extreme overloading at idle speeds, etc or is a component in need of replacement? I never happens when outside temps are below 100F. Thx for the replies.
Old Jul 15, 2022 | 07:14 AM
Frankyy's Avatar
2014 TL
Hi Rhys Pieces did u ever find out what the issue was with your A/C system?
Old Jul 15, 2022 | 09:30 AM
The only thing I have heard concerns the clutch on the a/c compressor. If this is so, it might not be getting quite enough voltage when idling on very hot days. It goes starts working again once the car is in motion. Since heat can impact current flow, it sounds logical to me. I am seeing my mechanic next week and will ask him about it and if the age of the alternator (10 yrs/118,000 miles) is really the culprit.
Old Jul 15, 2022 | 10:51 AM
WDPanda's Avatar
You should get an AC tech to check out your refrigerant levels. This sounds like something from low levels of refrigerant.
Old Aug 2, 2022 | 04:02 PM
Fixed!
Took it to my mechanic and he found one leg on the high side pressure sensor was shorting out under the extra heat of stop and go driving in our summers. He patched it and all is well again.
miner
3G RLX (2013+)
Apr 24, 2016 09:20 AM
speedemon90
Sep 21, 2011 12:04 PM
Scrib
Jun 22, 2009 09:05 AM
gr8dale72
Jul 16, 2008 01:55 PM
bioyuki
Oct 19, 2001 09:24 PM
