ABS sensor wire snapped
Old Jun 10, 2014 | 10:52 AM
Dgospavi's Avatar
Darko
hey guys,
i had h&r springs put on and the rear driverside brake abs sensor wire snapped. dealer wants $240 to fix it. guy that installed not taking ownership. In the meantime i need to get it fixed asap since its a safety hazard. Any recommendations?
Old Jun 10, 2014 | 10:57 AM
potmilkz's Avatar
DIY.. if you want to save 240 bucks..
just saying,.. how hard can it be..
Old Jun 10, 2014 | 11:12 AM
acupower's Avatar
Depending on where it snapped you may be able to solder it. Just make sure you use shrink tube after and maybe a couple of layers of electrical tape to ensure that it will not short.
If the wire snapped right were it goes into the sensor then you will not be able to solder it. You will need to remove the sensor and replace it. Buying a new sensor will not be expensive. You are looking at around $60-80 on ebay. However, removing the old sensor may be tricky. The sensor is bolted onto the hub and tends to stick to the hub even when you remove the holding nut.
So make sure that you don't try and force it out or you will break it. If you break it then you are in for trouble. The axle would need to be removed from the hub so you could push the stuck sensor out from the inside.
Anyways, I have not done this on the TL but I did it on my Accord. From the looks of it, both the TL and the Accord have similar designs for the ABS.
Old Jun 10, 2014 | 11:22 AM
acupower's Avatar
Here is a diagram of the ABS sensor (notice how it goes into the hub). This is not an Acura diagram but it is similar:
And here is a link with a picture of the actual Acura sensor:
http://www.ahparts.com/buy-used/2009...-TK4-A02/66271
Old Jun 10, 2014 | 12:05 PM
potmilkz's Avatar
if you are not mechanically inclined.. i say you bust out your wallet and pay the man... somethings you just cant avoid..
Old Jun 10, 2014 | 12:17 PM
lift3d_'s Avatar
rock the block
can't believe the guy who did it won't take ownership...i assume you escalated this to his management/corporate? worth mentioning that if he won't take ownership of the issue that it is likely a liability concern for him, or he already knows how big of a repair it will be.
otherwise, I wouldn't recommend tackling this yourself seeing as you already had to get someone to do your springs for you (no offense, I couldn't do it either haha).
Old Jun 10, 2014 | 12:18 PM
big10purdue's Avatar
For $240 I want the peace of mind that it's done correctly. Hospital bills cost $240 per minute. I'd take it on the chin and fight with the spring installer after getting it fixed.
Old Jun 10, 2014 | 12:28 PM
acupower's Avatar
It really isn't that difficult at all. Don't be discouraged by people telling you otherwise. Basically, if the sensor is stuck to the hub DON'T try and take it out. Go to a mechanic. If the sensor comes right out, then the whole job would take you 20 minutes max.
Old Jun 12, 2014 | 08:53 AM
Dgospavi's Avatar
Darko
Thanks guys lots of good info…. i found a guy who will do it for half and thats with replacing the cable.
Jamus22
Jun 11, 2023 10:08 AM
RobbDizzle
Oct 15, 2015 11:16 AM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
thegipper
Sep 28, 2015 01:01 PM
