2013 TL SH-AWD P0301 code
Old Jun 26, 2019 | 03:51 PM
Harrison Wolfe's Avatar
6th Gear
As I was pulling up to work yesterday I felt a slight shudder of the engine while reversing into a spot. I turned the car off waited a few minutes and then re started the car. It had a very hard time starting. I then left work at the end of the day and about 20 miles into my trip the car shuddered again and the check engine light began to flash. It pretty much powered down and wouldn’t let me go above 40 mph. After I pulled over and out it in park it gave me the following codes...
Check engine-P0301
Awd-77
check emissions
check vsa
check oil level
the car is currently at an Acura dealership and after an hour or trying to diagnose the problem they have called and said they are going into the second hour. The coil packs and spark plugs for cylinders 1-4 are fine and they are saying it may be far more serious than just a coil pack or misfire. Any help here would be great guys. Thanks so much
Mileage on car is 72,450
Old Jun 26, 2019 | 04:42 PM
Reorge's Avatar
See TSB 13-024 - MIL Comes On With DTCs P0300 Thru P0306 in the 2013 TSB thread.
https://acurazine.com/forums/fourth-...letins-945425/
Keep us posted. Good luck.
Last edited by EE4Life; Jun 26, 2019 at 06:48 PM. Reason: Edited post to add TSB link
Old Jun 26, 2019 | 06:46 PM
6th Gear
Have you heard of anyone else having this same issue? I have an extended warranty so hopefully something like that would be covered!
Old Jun 26, 2019 | 06:57 PM
EE4Life's Avatar
Forum Contributor
Does your car fall within the VIN range in the TSB?
Old Jun 26, 2019 | 07:14 PM
6th Gear
Unfortunately, it does...
Old Jun 27, 2019 | 07:23 PM
6th Gear
Follow up: apparently 2 fuel injectors went bad and that’s what caused the misfire. Fortunately everything is covered under warranty. Thanks for the help though guys I really do appreciate it.
Also had a quick question for anyone still here. I am opting to have a software update along with the 3 time drain and fill transmission service to try and help with my torque converter issue. I have a bit of tach haunting and hopefully this helps the issue. Any input on that would help as well if anyone has had the same issue.
Old Jun 27, 2019 | 08:33 PM
Reorge's Avatar
ABSOLUTELY get the trans inline filter changed.
Old Jun 27, 2019 | 09:32 PM
6th Gear
Okay I’ll call tomorrow morning first thing to have it done as well. I’m hurt that’s not included in the transmission service they provide?
Old Jul 1, 2019 | 07:27 PM
6th Gear
Okay so a follow up for you guys that commented.
After replacing the injectors that were bad, they then called me a day later to inform me that a coil pack and a spark plug were also bad and needed replacing. I just opted to replace all the spark plugs and went ahead with the repairs. Was scheduled to pick my car up today and received a call that my car was misfiring on cold start up and I would not be picking up my car today. They then called a second time today to inform me that it was in fact bad gas that is causing all these issues and they are not even sure that it’s water in the fuel. They said they really don’t know what it is and the inside of my fuel tank looks like a lava lamp. I now have to pay for them to pump it out and dry the tank out using some powder and will not be receiving the car back for a couple more days. Anything else I should be worried about here because at this point I’m not sure what to expect next? Thanks again guys any input would be great.
Nkmndz
Apr 7, 2017 08:00 AM
CL305
1G CL Problems & Fixes
Sep 26, 2012 01:03 PM
LIL_DUDE2ND
Apr 16, 2008 07:25 AM
ndawood
Aug 27, 2005 09:39 PM
