2013 TL SH-AWD new engine block
Old 03-30-2016 | 10:49 AM
Mathijs van der Linden's Avatar
5th Gear
Hi everyone. Been browsing here for awhile wihtout posting and thought I would let you know what just happened to my TL this last week. I have a 2013 SH-AWD with the California package and bought it used last fall. Love the car and enjoy driving it very much.
Here is what happened. I was idling at a stop light on the way to work and suddenly the car started running really rough and errors started to pop up on the screen. Had the engine light on, emission error, AWD error and hill assist error. Took it into the dealer the next day and after troubleshooting they found it was misfiring on cylinder 3. They checked all the usual suspects, coil pack, injector, spark plug etc. None of it fixed it. They sent the data to the factory and they concluded it needed a new engine block with possible scoring on the cylinder wall. Luckily it is still under warranty otherwise it would be a pretty expensive fix. I have 46k miles on it. Part that sucks is that there are no engine blocks available. ETA is May for a new engine block.
Anyone else have had engine issues like this?
MV
Old 03-30-2016 | 06:36 PM
JM2010 SH-AWD's Avatar
That's a new one. Did they say what caused the cylinder scoring in the first place? Had to be a broken ring, damaged piston or damaged valve, putting debris in the cylinder.
Old 03-30-2016 | 06:55 PM
5th Gear
Unfortunately they did not take the engine apart during troubleshooting. I would like to know also what the exact cause is. They sent the data back to Acura and then Acura made the call to change the engine block after their troubleshooting. Hopefully I will find out after they swap engine blocks.
MV
Old 03-30-2016 | 07:18 PM
Edward'TLS's Avatar
6G TLX-S
Are you given a replacement car to drive ?
Old 03-30-2016 | 07:51 PM
5th Gear
They gave me a brand new '16 MDX to drive. Not to bad. Lots of gadgets on it to play with.
MV
Old 03-31-2016 | 12:29 PM
EE4Life's Avatar
Forum Contributor
Does your 2013 TL SH-AWD VIN fall within this range (VIN 19UUA9...DA000001 thru 19UUA9...DA005530)?
Old 03-31-2016 | 04:59 PM
5th Gear
Yes the vin number falls right in the middle of that range. Is there a known issue with those vehicles?
MV
Old 03-31-2016 | 05:49 PM
EE4Life's Avatar
Forum Contributor
MV
MV
Yes, your issue could be TSB 13-024.
TSB 13-024 - MIL Comes On With DTCs P0300 Thru P0306.
Applies To: 2013 TL SH-AWD – From VIN 19UUA9...DA000001 thru 19UUA9...DA005530
http://www.urvi.net/forumfiles/SB/B13-024.PDF
http://techinfo.honda.com/Rjanisis/pubs/SB/B13-024.PDF
Old 03-31-2016 | 06:48 PM
5th Gear
Thank you good information.
MV
Flipster23
Norcal
262
05-04-2023 02:47 PM
Alexander Rousseau
03-12-2016 12:20 AM
bigl27x
03-04-2016 08:20 AM
JustJustin69
03-01-2016 03:02 AM
ExcelerateRep
02-04-2016 10:57 AM
Quick Reply: 2013 TL SH-AWD new engine block
