2012 TL Fog light replacement
Old Dec 6, 2012 | 08:09 AM
rubeen's Avatar
Does any have or know where i can get instructions on how to replace my fog light on a 2012 TL? I ordered the light but the dealer wouldn't give me the instructions. I need to replace the passenger side fog light.
Any help is appreciated...
-thanks
Old Dec 6, 2012 | 12:28 PM
Kenstlshawd's Avatar
If you talking about the bulb then follow this:
https://acurazine.com/forums/4g-tl-2009-2014-123/g-005-how-install-hid-fog-light-kit-4th-gen-tl-863117/
If you replacing the actual light then follow the above steps as well. You will see that each fog light is held in by 2 screws.
Old Dec 6, 2012 | 03:58 PM
rubeen's Avatar
Thanks looks pretty simple, i plan to replace it this weekend.
Old Dec 9, 2012 | 07:55 AM
rthammer's Avatar
On the 2012 TL AWD the fog light ( bulb) looks more cosmetic then functional- too bad - - Can you improve it with a brighter bulb or will this cancel the parts warranty coverage?
Old Dec 16, 2012 | 09:54 PM
diamondmit's Avatar
You can replace it with anything of identical specification....however....
...because LED's produce more light while consuming lower power, you can go to a brighter light without violating the wattage maximum of the foglight.
good luck
dd
Old Dec 20, 2012 | 01:31 PM
niravp44's Avatar
How do you change HID headlight on a 2009 TL? Thanks
Old Jan 9, 2013 | 08:56 AM
CamPhil's Avatar
HID Low Beams - Replacement
Replacing your D2S low beams can be done by following these instructions:
https://acurazine.com/forums/4g-tl-2009-2014-123/g-006-how-replace-hid-bulbs-headlights-4th-gen-tl-863114/
Old Jan 9, 2013 | 12:10 PM
Mr Marco's Avatar
Fogs can help with seeing the roadway in weather, such as rain or fog, but really if you are not seeing the road with you headlights, something is wrong. Please don't be that asshole who drives with his fog lights on EVERY night.
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
theinsvnity
Sep 10, 2015 10:22 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
