2012 TL Fog light replacement
Does any have or know where i can get instructions on how to replace my fog light on a 2012 TL? I ordered the light but the dealer wouldn't give me the instructions. I need to replace the passenger side fog light.
Any help is appreciated...
-thanks
-thanks
If you talking about the bulb then follow this:
https://acurazine.com/forums/4g-tl-2009-2014-123/g-005-how-install-hid-fog-light-kit-4th-gen-tl-863117/
If you replacing the actual light then follow the above steps as well. You will see that each fog light is held in by 2 screws.
You can replace it with anything of identical specification....however....
...because LED's produce more light while consuming lower power, you can go to a brighter light without violating the wattage maximum of the foglight.
good luck
dd
good luck
dd
HID Low Beams - Replacement
Replacing your D2S low beams can be done by following these instructions:
https://acurazine.com/forums/4g-tl-2009-2014-123/g-006-how-replace-hid-bulbs-headlights-4th-gen-tl-863114/
Fogs can help with seeing the roadway in weather, such as rain or fog, but really if you are not seeing the road with you headlights, something is wrong. Please don't be that asshole who drives with his fog lights on EVERY night.
Marmbo
4G TL Problems & Fixes
09-21-2015 10:39 AM
prox
5G TLX Problems & Fixes
09-01-2015 03:03 AM
