2012 TL console
Old Nov 13, 2015 | 03:53 PM
Hscam's Avatar
5th Gear
2012 TL console
The leather has bubbled and begun to crack where my elbow rest on the console as well as where my knee rests on the door. After an outrageous quote from my dealer (not under warranty apparently), I decided to replace the "leather" but have been unable to remove the lid. Any suggestions?
Old Nov 13, 2015 | 10:27 PM
TheDingo's Avatar
Resident Dingo
I can't speak for the 4th Gen, but if I remember correctly, the console lid is attached to the center console piece itself on the 3rd Gen cars. It's actually all pretty easy to remove even if that's the case. Take it to someone local and you'll likely save a good bit as opposed to going OEM.
Old Nov 14, 2015 | 07:22 AM
Hscam's Avatar
5th Gear
Thanks for the response
I have pried the upper and lower sections apart, but there seems to be something restricting the back and preventing it to open enough to access screws. There might be a release which I haven't found (One of those easy if you know how things), but I hesitate to force the lid for fear of damaging the plastic pieces.
Old Nov 15, 2015 | 09:25 PM
TheDingo's Avatar
Resident Dingo
Do you see screws under there that can be undone? What I'm saying is the lid may not be removable from the console itself.
Old Nov 16, 2015 | 12:47 AM
csmeance's Avatar
I believe you need to remove the center console from the car, take off the rear vent trim to get it off.
Old Nov 16, 2015 | 03:05 PM
Hscam's Avatar
5th Gear
Wow!
That seems like a lot of work to replace the cheap leather. Has anyone actually attempted this?
Old Nov 16, 2015 | 09:53 PM
csmeance's Avatar
It's not the leather that's bad, it's the padding underneath that's crapped out and now the leather has no counterpressure from the back.
Acura used shit vinyl on the 2007-2009 MDX center console and that ripped and looked like crap. The padding has been an issue ever since the 2004 TL. I believe the older models wore just fine including the 2001-2006 MDX
Old Nov 22, 2015 | 10:32 AM
TheDingo's Avatar
Resident Dingo
It sounds like a pain in the ass but it's not. Just simple tools and a little patience will have it removed from the car in less than a half hour.
LipJones
Apr 25, 2016 10:33 AM
swift996
19
Feb 4, 2016 12:04 PM
OculiAquilae
Nov 25, 2015 09:48 PM
TLMichelle
1G TL (1996-1998)
Nov 15, 2015 08:20 PM
wowzer
Oct 31, 2015 04:52 PM
