Pcd - cel?
Best bet is to contact Richie @ RV6 and run the same question by him.
stevesin (01-24-2017)
Former Sponsor
If properly installed there should be no CEL.
The pre-cat deletes come with defoulers to space out the o2 sensor, if it throws a CEL you can try adjusting those by turning them in or out
And, if all else fails (which it shouldn't) you can always K-tuner it out!
We have the RV6 PCD's in stock, ready to ship here: RV6-PCD-TL-4G - RV6 Pre Cat Delete - Excelerate's Honda & Acura Store - Japanese Performance Specialist
Good luck!
Good luck!
thanks for the responses, just had them installed. only thing irking me is the gas smell, but i'm hoping it eventually goes away.
and I will be getting ktuner, just seeing if i can go the used route before i go the brand new route
keeping the stock jpipe for the time being.
just sucks that nobody local sells ktuner, i've tried 4-5 places. might have to bite the bullet and get it online
The Original Shawdy
I have PCD and no check engine light. I did but it was due to the defouler being loose.
I have PCDs, Jpipe and full exhaust and there is a lot of back pressure but it puts down good power and it's loud. Also have it custom tuned. If you want to avoid the rasp, get high flow precats (HFPC).
carbonTSEX (02-05-2017)
The Original Shawdy
That's in reference to PCD with an aftermarket Jpipe.
Curious how that combo sounds with stock exhaust.
KarKraze (02-07-2017)
"CarbonTSEX" gave you the correct answer. The J Pipe with third cat delete as a stand alone mod will give you any rasp and will enhance the tone slightly.
With the reference to time to install mentioned in another thread. The Removal of the Second Cat is difficult due to limited space. It is time consuming and if you are going with HFPC the re installation is just as time consuming. If replacing with PCD then the install is simpler but it is still difficult to remove the Stock Cats.
I stayed away from the PCD' s mainly because of the rasp and gas smell. Love the HFPC and J Pipe combo though.
carbonTSEX (02-07-2017)
The Original Shawdy
Former Sponsor
You can see it online here: KTunerFLEU - Flash Based Hardware - Excelerate's Honda & Acura Store - Japanese Performance Specialist
Don't forget to check us out for your performance needs; PM me for quotes and with questions!
Couple of questions...... did you purchase the PCD new from RV6 ? Did you get spacers with it ? Did you scan to see what code you triggered ?
Not sure if the defoulers came loose but many times the CEL will not come on immediately, they will come on after the ECU senses a particular parameter is constantly registering over X number of kms . Also far as i know certain driving style will trigger the CEL, gearing down from high RPM and pulling to red line.
I know my car was running rich with the Mods but without the tune. After the tune I am getting a near perfect air / fuel mix.
carbonTSEX (02-09-2017)
The Original Shawdy
We cant really give you advice on how to correct the code unless you get it scanned. From there we may be able to steer you in the right direction. In my case, you could move the defoulers with your hand so it was easy to tell. Not sure how they came loose but it was an easy fix.
I as well love the HFPC/J-Pipe combo as well. I also have the Ktuner but running on base map... I'm sure car running rich even with the base map because every now and then you can smell it especially when gearing down or coming to a stop from flooring it. Love my set up tho but ain't had much time to enjoy it since I did it right near winter started. My reason for HFPC just simple... ain't want that gas smell with the lil princess in the car. And "supposedly" have more low end TQ.
carbonTSEX (02-11-2017)
One guy in here actually did it and ended up installing his stock J-pipe and I bought the aftermarket one from him... He said the exhaust was deeper and more growl to it but prefer the PCD'S with the stock setup.
The Original Shawdy
Mine just smokes more than it stinks. Wife says she can't tell and doesn't mind it.
The Original Shawdy
