Coolant bypass and EGR Delete
Old Aug 14, 2012 | 12:22 PM
senile32nd's Avatar
Apple tech needing a h22a
can someone post some info on this for me, did a search and nothing for the 4g on here.. is it worth it as i am not worried about the cold as i am in florida...and if so how to do so....
Thanks in advance
any news on the JnR ecu?
Old Aug 16, 2012 | 11:15 AM
eazy's Avatar
WDP 4G
I'm sure the coolant is for keeping your car from over heating as well. Why would you bypass it?
Old Aug 16, 2012 | 11:25 AM
senile32nd's Avatar
coolant bypass is in regards to stop it from going in to your throttle body, they do that in case cold ass weather etc.... i think that is just looping it before the throttle body.. more interested in if anyone ever did a EGR delete our cars and if it made any difference..
Old Aug 16, 2012 | 11:44 AM
since we have the same general engine, the Jseries...
I'll chime in.
you are right, Senile. the Coolant is looped to the throttle body specifically for cold winters. in theory the butterfly in the TB will get frozen stuck. but you're in Florida and that doesnt seem likely.
on the 3G TL, the IAT sensor is sitting right on the throttle body.
this warm coolant runs through heating up the IAT and causing the ECU to think its warmer outside.
I have done the Coolant bypass mod. while it doesnt add horsepower or free up hp, it does keep the IAT cool!
on the 3rd gen side, we've also deleted the EGR with a plate.
this does throw a CEL and cannot be tricked. meaning resistors wont trick it. I plan to do this. Frees up 3-5 hp.
a step further would be deleting the PCV and adding an oil catch can
Old Aug 18, 2012 | 02:18 AM
Sandro's Avatar
I'm also pondering what to do about the EGR since I'm modding exhaust on my 2010 ZDX now (J series motor also).
There is little info out there but some people told me that simply blocking the EGR valve may lead to unstable engine operation, as well as deleting front cats (what I plan to do) without touching the EGR.
Any thoughts?
Old Aug 18, 2012 | 08:06 AM
^negative.
you can find the EGR block off plates on ebay, for like 10-17 dollars.
its pretty cheap to TEST.
I say test, because it might not be in favor to you. but what the heck,its only 17 dollars and you can put the EGR back on, if you choose.
I have the RV6 V3 PCD's(Pre-cat deletes) for my 2006 TL.
you might want to check out what Richie is doing for the ZDX.
http://rv6-performance.com/
his contact information is there(email and phone)
Old Aug 18, 2012 | 09:56 AM
Sandro's Avatar
Richie is still in the process of making the J-pipe for MDX which will also fit the ZDX, waiting for it as well
Old Aug 20, 2012 | 10:22 PM
3rdGenHybrid's Avatar
Wouldn't just unplugging the egr do the same thing as blocking it off? The egr is normally closed, so disconnecting the connector would keep it closed.... ?
Old Aug 20, 2012 | 10:54 PM
silkysmooth_96's Avatar
The EGR system has feedback sensor on it (based on the electrical diagrams I have). Unplugging it would definitely throw codes. Why not block it off, but leave the valve plugged in? I don't know how it'd detect if there wasn't flow..
Old Aug 21, 2012 | 06:32 AM
musty hustla's Avatar
I didn't know modern engines still have EGR valves. Do hondas/acuras have an air pump as well?
Old Aug 21, 2012 | 07:45 AM
Blocking it off would still set a code, p0401 egr insufficient flow??
Old Aug 22, 2012 | 04:07 PM
Sandro's Avatar
if I get it right (didn't dig deep yet) the EGR block plate replaces the valve itself so it will be disconnected either way
based on some civic owners reports the "check engine" comes up after a time and not always
I got the EGR block plate and may try it some time soon but apparently we'll need a tuned ECU if we go that far. I know some ECU's have an option of "EGR off" but no idea how it works out in reality
Old Aug 25, 2012 | 04:04 PM
senile32nd's Avatar
wonder if JNR's ecu will have this option
Old Aug 25, 2012 | 06:22 PM
^as of right now, no.
people with the J&R and blocked off EGR still get the CEL
Old Aug 26, 2012 | 01:04 PM
Sandro's Avatar
Hondata Flashpro ECU has this option
i thought about other ways to trick EGR like connecting the pipe leading to EGR valve straight to intake manifold instead of exhaust pipe, so EGR would take clean air instead of exhaust, but this could interfere with fuel maps and cause troubles for the engine
so I guess the only good way to get rid of the EGR is tuned ECU
Old Aug 27, 2012 | 03:44 AM
Edward'TLS's Avatar
6G TLX-S
But Hondata has nothing available for the J-series V6 engine family. So there is currently no permanently solution to bypass the EGR for the TL sedans without setting off the engine warning light as well as throwing out trouble codes.
Old Aug 27, 2012 | 06:02 AM
^exactly!
Old Sep 1, 2012 | 02:58 AM
Sandro's Avatar
I guess I found the EGR workaround
http://www..net/forums/7th-generatio...e-bye-egr.html
trying to register on that forum to get in touch with that dude. seems like he's selling these EGR tricks
Old Sep 1, 2012 | 10:09 PM
Pseudomaniac's Avatar
I blocked the EGR off on a J32A2 ground up rebuild I did a few years ago. The results aren't worth the effort.
The coolant bypass trick goes back for years on Hondas. You've got a coolant line that runs into the TB and a coolant line that runs out. Basically, you just take a longer piece of hose and skip the throttle body. The logic here is better continual HP through reduced heat soak. Again - you're not going to notice any gains unless you're dyno racing or tracking the car competitively.
If you want cheap power on this motor, go get a set of the magnaflows and have them welded in with your stock tips. Should be less than a $250 investment - and you'll feel (and hear) the power.
Old Oct 25, 2021 | 04:53 AM
Atanas Dimitrov's Avatar
can you disable egr code with ktuner? how eaxctly does removing egr valve free up power? thanks
Old Nov 12, 2021 | 12:44 PM
wheelz420's Avatar
This is a good video for the EGR delete
Thanks in advance
Old Nov 13, 2021 | 07:00 AM
Ktuner does.
Old Nov 16, 2021 | 05:09 PM
dzionny_dzionassi's Avatar
you dont want to block EGR, it cools valves. There will be no gains.
Other engine manufactures have variable valve timing lift on exhaust side. This way they can program more cooling for exhaust valves So no EGR needed.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
tsx_boy
Dec 13, 2019 08:33 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
Username 0
2G TSX Performance Parts & Modifications
23
Sep 28, 2015 09:09 AM
