Anyone running the underdrive UR crank pulley?
Former Sponsor
The stock diameter pulley will still provide some great results. It weighs significantly less that the stock pulley so you have less rotating mass. You'll notice the RPMs will move quicker and you'll gain a few horsepower. The nice thing about the stock diameter is you can use your oem belt.
XLR8 Aluminum Pulleys - Excelerate Performance - Japanese and European Performance Specialists!!
If you're looking for underdrive, I recommend the UR pulley with the belt which we have in stock and can ship right away. Underdrive pulleys basically shorten the travel of the belt and can again increase horsepower and responsiveness.
Unorthodox Racing Pulleys - Crank Pulley - Excelerate Performance - Japanese and European Performance Specialists!!
echodigital (10-31-2018)
I found another guy on YouTube that had the same problem with his 09 V6 Accord, he ended up going back to stock as well.
Here is my video of what it sounds like
https://www.youtube.com/watch?v=xbkN4SjXU4Y
Here is the Accord video
https://www.youtube.com/watch?v=TIaSbRyfBe0
I also had the Crank/PS/Alt UR underdrive pulley kit for my 01 Accord V6 and had absolutely no problems at all. It might just be their newer stuff or maybe I just got a bad pulley.
Weight can be, but I that depends on the initial weight of the item.
I just put under drive pulleys (power steering and water pump[I also put on a high performance endurance racing part to turn up the volume of flow])on my BMW and the difference was pretty massive. Car pulleys harder in every gear at every rpm. I was surprised.
Now every car has different engineers, and in my case BMW really overdrives their accessories.
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
