hi all,
I'm helping someone to install rear spoiler and back up camera on the base model.
We found a camera with all the wires but not sure about wiring diagram to hook it up.
If anyone know about this or can share wiring diagram, it'll be very helpful.
Thanks.
Wiring diagram for where the camera stuff plugs into the navigation display unit screen:
Component locations (I'm sure you already understand this much, but just in case):
And if you're only connecting the camera, you can ignore the second connector with the green and white wire. According to the trunk lid opener wiring diagrams that's for the keyless entry trunk release button on the spoiler. They just packaged them together since they go through the same rubber grommet.
Thanks for the diagram. You're a life saver.
So basically, i just need to connect the White for Camera output, the Black for Ground and the Green for power supply then I should be all set.
