using Voice Recog making Phone Calls - "call Pete" easiest way?
In the 3G once you had saved ph#s w/ a voice tag. - All I had to do w/ press the phone button on the steering wheel and say for instance "call home" and the car would dial my home #.
I found the voice tag stuff for the 4G - but I cant just press a single button and say 'call or dial Pete'? I have to go to the info screen , then phone screen, then turn the dash button until its over the person's name/# I want to dial from the speed dail section of the phone screen - and then say call Pete?? - I'm I making this too hard or have we gone from 1 step in the 3G to 5 steps in the 4G??
anyone know?
anyone know?
I think I'm getting ready to pull the trigger on a 4G SH-AWD--just debating color. However, I'm interested in hearing the response to this question; I cannot imagine they would take such a huge step backward. But, if they did, that might give me pause. I use the bluetooth handsfree all the time; it is one of my favorite features on the car.
CR, it works for me so it might be an overlooked step somewhere? Did you set up the voice tag correctly?
For me when I'm listening to XM, I'll hit the voice activation button quickly then let go and say "call Rob home" and the XM switches over to phone mode and bang...? I will go down to the car and retrace my setup as to what I did to make it work for ya... I'll post later.
Okay, so you have your phonebook imported, check.
You have your voice tag setup, check.
So when listening to any audio source and it's time to make a call, hit the left phone button on the steering wheel, then hit speak button just below, then say "call Bmode", and you should be all good.
I'm still getting accustomed to this myself. But I think bmode is right: you have to first hit the phone button on the steering wheel, and then hit the talk button on the steering wheel and then say "call (or dial) whoever".
Also have a Blackberry Storm - contacts imported to TL perfectly.
I never post !!!
anyone know?
anyone know?
Isn't that correct?
On my 4GL with a phone number voice tagged, I need to press 2 buttons to dial a number. First, I press the "off hook" button on the steering wheel to get to the HFL page. Then I press the "Talk" steering wheel key and say "dial <voice tag>", and the call is made.
On my old 3G, I could do this with a single button press (the hfl off-hook button).
I think the issue at hand is that the software engineers who designed the nav/HFL system switched to a paradigm where the only voice commands you can ever give are the ones currently displayed on the nav screen, except for climate, audio, and display commands. Or said differently, the HFL (telephone) commands now work like many of the other commands in that you can only "say" the commands highlighted on the screen when you press the "Talk" key. For example, note that when you press the "talk" key, speakable commands are highlighted on the nav screen.
Personally, I wish they would have made the HFL voice commands usable from any mode (or usable regardless of what's displayed on the screen). Hopefully, this can be "fixed" in a subsequent release. I am hoping the SW engineers in question don't look at this new behavior as a "feature", as I certainly look at it as a bug!
But I still love my 4GL SH-AWD!!!
-- Dave
-- Dave
I don't see this as a problem that they need to fix but rather us TL loyalist just adapt two. It's too buttons, and a voice prompt. By the way after hitting the phone "off hook" button I just say "call bmode" and don't say anything about voice tags, and it works fine. I also noticed that I only have 20 speed dials? Now this is a serious limitation, as the old TL had about 50? What's the deal with that, or am I missing something here?
got it now
It's ok MikeElmendorf w/ the help of TLorNotTL and cds-tl I have it down to their 2 buttons or steps
like they said once you have voice tags step up:
1: don't worry where the screen is
2: press phone button
(brings system to phone screen)
3: press talk button and say 'dial Pete'
thanks guys!
So now that we got that step down, how do we dial a voice activated phone number? We used to be able to simply hit the phone button which muted the music, and say "dial 555-1212". I couldn't figure that one out today on the way home from work?
Bmode:
Three things. In my post, the syntax "<voice tag>" was meant to imply that at that point, you would say whatever your voicetag was (in your example, it would have been "bmode"). You don't have to say the string "voice tag"!! Sorry if that wasn't clear.
Relative to dialing a number, here's what I've found:
1) press the "off-hook" button to get to the HFL page
2) press the "talk" button and say "dial"
3) press the "talk" button again and say the number
4) press the "talk" button again and say "ok", or press down on the joy-dial
My third point is that although I do love my new TL, I do consider these regressions in the simplicity of the 3GL HFL voice commands to be a bug!! Acura (actually, the navi/hfl vendor) made some common things much harder than they were on the 3GL. When I pay +43K for a car, I don't want to adapt to the car, I want the car to adapt to me
Now again, I love the car, but relative to HFL voice command support, the 4GL is a step backwards, in some respects.
By the way, if you press the off-hook button twice, HFL will automatically call your first speed dial number! I found this out by accident, much to my wife's annoyance, as I learned the car while she was in a mtg
-- Dave
-- Dave
Ah good stuff, I read that in the manual but it didn't make sense, but now I see the light. That's funny regarding your wife, at least she can't say "you never call me".
Judging by the way it works, I think they may have changed HFL vendors. I suspect that the original system was Motorola or Johnson Controls. My guess is that Alpine is doing it now by the way it is so tightly integrated into the navi system.
Hey Hugh, it's good to hear that the Storm bluetooth works well! I had the Razor and Curve in my old TL, and the both were unstable. My Q is does the storm work with AcuraLink?
What is worse here is my cell phone does nto support importing the phone book and there is no way to manually enter phone book entries without have call histroy liek there was on the 3G. Boy Acura "ADVANCE" my ass, the HFL in the 4G is astep backwards..
cycdaniel
12-17-2019 10:58 AM
Oakes
Wash & Wax
10-12-2015 11:17 AM
brandnewcolony
09-12-2015 10:39 AM
IndycarFaster
09-11-2015 02:52 PM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
