Stereo wiring diagram
Old May 7, 2012 | 01:45 PM
Ladkahaidesi's Avatar
9th Gear
I had tried doing a search on the forums and the internet but could not find the stereo wiring diagrams for an 09 Acura TL tech. I just recently bought my car and want a little bit more punch for the low end. Does any have the diagram?
Old May 7, 2012 | 01:54 PM
gibbyisgibby's Avatar
Are you adding aftermarket subs?
Old May 7, 2012 | 03:00 PM
9th Gear
Yes I have everything wired except the loc because I don't know what wire to connect to
Old May 8, 2012 | 03:54 PM
9th Gear
Or if anyone knows what wire colors I should connect to
Old Dec 23, 2013 | 08:59 PM
willmosley's Avatar
I think this is the location:
http://www.flippydigits.com/docs/200...schematics.pdf
Old Dec 24, 2013 | 02:25 PM
ngravatt's Avatar
2013 sh-awd adv
i found it somewhere. all you have to do is clip on to some of the wires going into your factory sub in the rear. then you get the RCA outputs that would go into your amp. here is a link to the service manual. let me see if i can find the wires you need to connect to. i think i bookmarked it on my home PC:
service manual
https://acurazine.com/forums/4g-tl-2009-2014-123/acura-tl-service-manual-899572/
Old Dec 24, 2013 | 02:29 PM
zapco's Avatar
Ditch the factory amp and wire direct to aftermarket amps. Invest in a DSP and ditch the LOC's. I am selling a 360.3 DSP with about 40 hrs use if interested.
Old Dec 24, 2013 | 02:50 PM
ngravatt's Avatar
2013 sh-awd adv
more on the factory wires to go to aftermarket amp.
as zapco said, you gotta have an aftermarket amp for an aftermarket sub.
https://acurazine.com/forums/4g-tl-audio-bluetooth-electronics-navigation-294/how-replace-stock-subwoofer-w-tech-835671/
Old Jun 21, 2014 | 08:47 PM
Eiswritsat's Avatar
TL owner
do you have to unplug and active noise mics to add an aftermarket sub?
4drviper
Apr 23, 2025 07:13 PM
quanaman
Jan 9, 2023 07:33 PM
SilverJ
4G TL Problems & Fixes
15
Oct 13, 2015 05:14 PM
SUPRMN84
Oct 7, 2015 09:46 PM
27trains
Sep 30, 2015 09:44 AM
