How to replace stock subwoofer w/tech
Old Oct 12, 2011 | 05:38 PM
eatmypoo's Avatar
I'm sure there are plenty of posts on here about how to replace my stock sub on my 2009 TL w/tech package, but the only info I can seem to find is for 3rd gen TL's and TSX's. Anyone know where I can find some info, or do you have info? Thanks.............
Old Oct 12, 2011 | 05:55 PM
EazyRider562's Avatar
Did you blow it? Call the dealership bro! They should point you in the right direction! Hope that helps!
Old Oct 12, 2011 | 06:41 PM
eatmypoo's Avatar
No, I didnt blow it, I just want something with a little more push. Not something crazy, or thumping. Just something a little more.
Old Oct 13, 2011 | 05:10 AM
KarKraze's Avatar
I needed a little more bass than what the factory system was capable of producing so i did this
it sounds low and clean and does not take up much space,bass control still functions from the head unit.
Old Oct 13, 2011 | 08:27 AM
TinyRK's Avatar
Autofahrer
How did you wire it?
Did you just disconnect the wire from the factory-woofer into the amplifier?
Old Oct 13, 2011 | 11:39 AM
gibbyisgibby's Avatar
You can hook the wires from the factory sub to the amp as long as your amp is compatible with high-level speaker line outputs. If not you need a converter to a low-level.
Old Oct 13, 2011 | 12:01 PM
TinyRK's Avatar
Autofahrer
Sounds like a PITA.
Has anyone a wiring-diagram of how the hookup should be like?
Old Oct 13, 2011 | 12:54 PM
Pseudomaniac's Avatar
You have to pull power from the battery to the trunk and find a groud point for the amp as well. Pulling the power wire was a PITA - you have to follow the hood latch up into the fender well (remove fender liner on drivers side).
You can run the leads to your input off the speaker leads to the stock sub with a speaker to line level/rca converter box ($20 max). This allows your stock head unit's subwoofer volume controls to still work with the aftermarket unit properly.
There is a guy on here making an AWESOME enclosure box for the 4G unlike the ghetto setup above...but plan on a $350 speaker box.
Old Oct 13, 2011 | 06:29 PM
potmilkz's Avatar
LOL, ditto.
do it once, do it right.
AndrewS
19
Mar 14, 2024 06:59 PM
Joseph Stansbury
34
Dec 4, 2015 01:57 PM
sockr1
Oct 1, 2015 01:31 AM
d.lim
Sep 15, 2015 08:54 PM
yahelou
Sep 6, 2015 09:12 PM
