Sound system.
Old Jun 1, 2011 | 04:21 AM
ninaincy's Avatar
Sound system.
My rear center woofer is rattling. It has ever since I have bought the car. I havent found any website that sells them. I went on evay and they a have a used one. I am kinda leery on purchasing it.
Does anyone know of any place I can order from??
If you do, id surely appreciate knowing.
Thank you!!
Old Jun 1, 2011 | 08:42 AM
scfa's Avatar
You don't mention your miles or year but if your car is still under warranty this will be covered. acura has come out with a new sub/part to fix this issue. my car is going in on saturday for the fix. i will post the part number if you need it.
Old Jun 1, 2011 | 10:03 AM
Treblig's Avatar
Are you certain it is your sub and not some loose trim pieces?
Old Jun 1, 2011 | 07:00 PM
TurboRush's Avatar
+1 for trim pieces, if you haven't already its worth putting on a song with a lot of bass and jumping in the back seat and pushing around to see if applying pressure on a particular piece kills the rattle.
I havent seen this in the Acura but I had the issue in the ex's ES350, few twists of the screw driver and rattle was gone
Old Jun 1, 2011 | 09:59 PM
Loli's Avatar
In case it is your woofer, if your car is an 09 or later the woofer can be purchased from Bernardi Acura. I have seen them there. I did not look for any older models.
Old Jun 7, 2011 | 09:16 AM
jnc2000's Avatar
The rear deck fitment was way off on my TL... one of the main reasons why I pulled it and added deadener. Sounds much better and quelled all vibrations and noises.
Old Jun 7, 2011 | 12:08 PM
gibbyisgibby's Avatar
Mine was rattling too but it wasnt a blown speaker in this case it was just the rear deck. The dealer fixed it under waranty
Old Aug 18, 2011 | 10:57 AM
dance2dp's Avatar
6th Gear
Thank you!!
If you are looking for replacement oem parts then try http://www.hondapartsunlimited.com/
Fast shipping and great prices but if you are still under warranty then take it in to the dealer.
Old Aug 18, 2011 | 10:59 AM
Flipster23's Avatar
Just get a 10" sub and enclosure sounds better anyways.
Old Aug 18, 2011 | 11:05 AM
dance2dp's Avatar
6th Gear
Or go 12" sub with an extra amp for juice just in case you ever have those days where you just need big BOOM in your sound.
Old Aug 18, 2011 | 02:15 PM
dwest1023's Avatar
I bought some stick on sound deadening material(forgot the name). Not only did the rattle go away, it tighten up the bass as well. I was happy with that repair.
Old Aug 18, 2011 | 06:09 PM
Edward'TLS's Avatar
6G TLX-S
Dynamat ?
mlody
Dec 4, 2019 02:11 PM
lbabus
Oct 12, 2015 07:00 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
agupta3224
Sep 22, 2015 08:08 PM
