Questions on Importing music to HDD
Old Apr 25, 2014 | 03:03 PM
cbiccum's Avatar
HI all, just traded in my 2007 TL for a 2012 Elite. Love it so far.
I really like the HDD music setup and so far after ripping about 6 cd's gracenote couldn't find one of them.
From the looks of it though the only want to import music is by having a true audio cd. A cd with MP3's won't import, nor will a USB drive plugged in with either MP3 or wav files import (that I can see)
My problem is that about 8 years ago I ripped all my cd's to itunes and threw out the originals. Went totally digital. Does this mean I will need to buy a bunch of blank cd's and rip the albums back into audio cd's?
This would be very painful. Is there any other options? Is there anyway to create a USB stick so the TL think's it's a audio cd? Anything options?
Old Apr 25, 2014 | 03:21 PM
sockpuppet's Avatar
Not only painful, but also impossible. In my experience (and perhaps others can back me up) burning an audio cd from mp3s, even if it mirrors the tracks on the original CD, will not be recognized by Gracenote. Only retail cds will do this. Also, DVD audios will note update with Gracenote.
It appears you are out of luck. Sorry.
Old Apr 25, 2014 | 03:49 PM
C8N's Avatar
C8N
I've burned audio CDs and they uploaded into the HDD fine.
Old Apr 25, 2014 | 08:02 PM
sockpuppet's Avatar
Sure, they'll upload to the HDD fine. Do that with 100 cd's, and you'll have a thousand or so tracks labelled "No Name".
You can then spend a long weekend burning through a tank of gas while you input track titles and album info manually. If that's what OP meant by his question, then I misunderstood.
Old Apr 30, 2014 | 01:53 PM
cltgt's Avatar
I don't know if that method will work. I believe Gracenote works by picking up a code on the original disc that has all of the information embedded.
Old May 23, 2014 | 10:28 PM
swannyva's Avatar
As there was never a "plan" to encode identification data on audio CD's, the way Gracenote works it by comparing a set of statistics collected from a music CD to those in the Gracenote database. For example, number of tracks, size of each track, size of the entire disk, etc. I'm not aware of all the details, as this is from memory when "IMDB" first began accumulating this information and offering return information. One of the early crowd sourced initiatives, if you will, as much of the database was provided by users who typed the album information into the IMDB program. Feel free to correct anything I have stated, because as I said, it's from memory.
Old Jun 7, 2014 | 02:14 AM
andrewcjduong's Avatar
Unless you listen to bee gees or music that is somewhat old, the gracenote and the whole HDD will be pretty useless. I have a Frank Ocean album from 2-3 years ago and Gracenote can't pick that up... Nothing hip hop really.
Old Jun 12, 2014 | 09:57 AM
cltgt's Avatar
Gracenote seems to find all of my CD's with no issue. Have you downloaded the latest update?
Old Jun 12, 2014 | 01:05 PM
lift3d_'s Avatar
rock the block
I've had zero luck with Gracenote, and have tried uploading songs purchased on iTunes and Beatport, as well as ripped/stolen MP3s. I don't think I've had a single song indexed properly.
I just make playlists on my phone (Nexus 5) and run it through bluetooth, at least I can see it on my phone.
Old Jun 12, 2014 | 02:12 PM
cltgt's Avatar
Well, it will only work with an original disc. Does not work with mp3's or custom audio discs. Has to be a disc you buy from the store.
Old Jun 28, 2014 | 05:16 PM
godawgs10tlshawd's Avatar
I have burned CDs from I tunes and they work fine
Old Jun 29, 2014 | 12:28 PM
cltgt's Avatar
Grace Note found all of the information correctly?
Old Jun 30, 2014 | 08:42 AM
swannyva's Avatar
I'm guessing that gawdawgs created CD's in the native format, not mp3.
Old Jun 30, 2014 | 10:56 AM
sockpuppet's Avatar
Even so, I wouldn't imagine that it would work, but clearly I'm wrong.
The latest update did tag a bunch of my cd's that previously were "not found". Still missing a bunch, though.
Old Jun 30, 2014 | 03:33 PM
Lioneltl's Avatar
How does one update Gracenote?
Old Jun 30, 2014 | 05:58 PM
sockpuppet's Avatar
Couldn't be simpler. Go to this site, input your details to get to the right download, then download to a USB stick (extract the zip files straight to the main directory, not a folder), and then plug into the connection in your console.
Then, with the radio set to "HDD", choose setup, and then navigate to "update gracenote database". Will likely take about 15 minutes or so.
After you're done, you'll have to go through each disc that's missing information and choose "Update Album Information"...updating the database won't retroactively update your albums.
Old Jul 25, 2014 | 07:44 AM
liquidneon's Avatar
So is it possible to pop in a USB stick and have that rip to the HDD? I tried this morning somewhat quickly but couldn't find an import option. the AUTO vs Manual "rip to HDD" was set to Auto... I tried pressing Scan, and checked all menus and didn't see anything...so what the hell do I need to do to get my MP3's from USB to HDD?!?
Help please!
Old Jul 25, 2014 | 08:31 AM
cltgt's Avatar
USB Stick with music on it will not rip to HDD.
Old Jul 25, 2014 | 08:38 AM
liquidneon's Avatar
So the HDD is ONLY good for ripping music from an audio CD?!?! Aka the 1000 songs I have on USB I cannot copy to my HDD unless I burn 85+ CD's first????
There must be a better way...
Old Jul 25, 2014 | 08:54 AM
cltgt's Avatar
Yes. And as far as I have ever seen, it needs to be an actual audio cd, not an mp3 cd.
Old Jul 25, 2014 | 08:58 AM
liquidneon's Avatar
OK so I'm going the USB route.
Any issues with me using a USB 3.0 device?
http://www.tigerdirect.ca/applicatio...815&CatId=3786
Or should I go with 2.0?
Old Jul 25, 2014 | 09:03 AM
cltgt's Avatar
Either works fine. If you want to be able to shuffle through all of the music, do not put them in separate folders.
snorf
Nov 4, 2019 06:44 AM
Aug 15, 2019 12:58 PM
SilverJ
1/2G MDX (2001-2013)
Sep 21, 2015 02:40 PM
datadr
Sep 12, 2015 09:12 PM
ja17
Sep 7, 2015 06:08 PM
