Problems with XM Reception 09 TL
Old Sep 22, 2009 | 07:53 PM
MIKEYDRED's Avatar
I have had the worse of luck so far with my XM reception (09 TL tech package) and XM does not seem to want to help, before I make a trip to the dealer just wanted to get some feedback from other's experience with XM in their 09 TL.
The signal strenght is very weak compared to my fiance's CRV and coming from an 04 TL where I never had reception problems. I spend half the time trying to find a channel that actual works, I am constantly getting the loading message but nothing loads? The few times I do get reception the slightess of interferances (i.e. trees, the signal is lost) Has anyone else experienced this or is this something I should have the dealer look at, I tried to explain to XM that if I can get some stations there is nothing wrong with the antenna,but they feel otherwise
Old Sep 22, 2009 | 08:34 PM
str8aero's Avatar
This is my first experience with XM radio - when I bought my first 09 TL. I never had any signal problems at all. I now have my second 09 TL (long story - different thread) - exact same car - and I lose the XM signal on this one pretty regularly. For example I lose it for an instant going under overpasses and when I pull into the garage at home. I guess I would have thought you would lose it under those circumstances, but I didn't notice it on the first one. I'm thinking about about asking the dealer if there is any 'tuning' of the system they can do?
Old Sep 22, 2009 | 10:22 PM
Kingmeow's Avatar
Just thinking out loud. If you can pick it up fine in your fiance's CRV under the same environmental conditions then I would suspect it's the car/radio. I would go to your dealer first before going to XM.
BTW, I lose it too once the car is in the garage. Satellite technology is line of sight. That's why my Dish Network goes out during heavy snow or rain storms.
Old Sep 23, 2009 | 08:52 AM
09tlsteve's Avatar
as aid, line of sight. I believe also southward obstructions like buildings. I lose signal under bridges and three short times in the shadow of my office building. The rest of the time -- no problems at all. I'm assuming the XM anrenna is the fin on the top (and not on the dash as the GPS receiver is), therefore should not be hurt by tint, etc. Maybe the fin is not wire in correctly? Maybe it's dirty?
Old Sep 23, 2009 | 11:15 AM
venom550pm's Avatar
My beer fridge is in
my wife has an 07 RDX, which is much like a CRV. As you can see from my signature i have an 09 TL. Our reception is the same. We both lose it going into the garage and under the same big trees.
Having said this, my last car was an 04 WRX. I had a kenwood receiver put in with Sirius installed. This cut out much less than either my TL or my wife's RDX. And when it did cut out, it didn't make the static noise.
Old Sep 23, 2009 | 01:26 PM
MIKEYDRED's Avatar
I have scheduled an appointment to have the dealer look at the car.It is not just a slight lost of reception that's the problem, it's the constant loading message and nothing happening (i.e. no music). I hope they do not have to take anything apart else I think I will do without XM, also forgot to mention on my original post that weather and traffic information is often unavailible also which is strange since i live in Boston and it was one of the first areas to have coverage available.
Old Sep 23, 2009 | 01:37 PM
Kingmeow's Avatar
Yeah, definitely a trip to the dealer. Those symptoms are indicative of the car/radio and not XM. BTW, I work in Boston (weekly commute). Do you know if Acura of Boston (Bernardi Acura) on Soldiers Field Road in Brighton is a good place for service? I work 2 miles from there so I was thinking if I need service I can use them and not have to wait until the weekend when I'm back in NJ.
Old Sep 24, 2009 | 08:19 PM
MIKEYDRED's Avatar
I am sure they are good for service I see them shutleling people in town with their silver MDX all the time. However I do not go to them since my 3rd generation days when they told me I couldn't afford a TL I need to get a TSX.
Old Sep 25, 2009 | 11:08 AM
venom550pm's Avatar
Lexus did that to me when i bought my WRX, told me i couldn't afford an IS300.
Old Dec 7, 2009 | 01:57 PM
Kingmeow's Avatar
Mike,
Was this resolved to your satifaction? What was done? Did they replace the radio? I just had something similar happened but not exactly as your case, though it's too early to tell if it's a one off problem.
https://acurazine.com/forums/4g-tl-problems-fixes-297/weird-xm-radio-problem-cut-out-until-stop-start-car-755154/
Old Jul 9, 2010 | 11:27 AM
Kzelones's Avatar
I have a 2010 RDX and can't get XM weather. Any ideas?
Old Jul 15, 2010 | 10:28 AM
kooty-sentinel's Avatar
Waaaaaaaaaa.
I've actually noticed the same problem in my '10 TL. Compared to the ZDX reception is horrible and I frequently experience signal loss - even in completely clear conditions.
Old Jul 24, 2010 | 02:19 PM
Illini Bill's Avatar
I purchased my 2010 TL about a month ago. Never had XM before, so nothing to compare it against. However, it is very tempermental. It periodically will not work, searching for signal, even on a clear day. Example today, go to the store XM does not work. Get out of the store, get in car and XM works perfectly. It is frustrating.
Old Jul 28, 2010 | 03:26 PM
danimal1968's Avatar
I've had my 2009 TL since 4/29/09. I lose XM reception in my garage, after going down half a level in my office parking garage, and when driving under a 8-lane overpass for our Outerbelt here in Columbus. Other than that I have not had any issues. If you're having those kinds of issues where your line of sight to the sky is not blocked at all, I'd get the car into the dealership to make sure none of the wiring has come loose.
Old Jul 28, 2010 | 06:42 PM
RSLTSX09XMNAVWX's Avatar
Weather is not a big issue!
Except for VERY heavy rain or VERY heavy snow, XM will come through unless a large building, ridge or bridge-building Blocks the line of sight to the Satellite. The Satellite is in a geosynchronous orbit 24K miles in space. If you were in the middle of the USA, you would look Due South and Up at a 60 Deg angle and there is the Satellite. XM, weather and NAV is Very Reliable. On my way from San Diego to Las Vegas, had 5 hours of perfect reception,, not many mountains or buildings in the Desert. Lost reception off and on when on the North side of the large hotels but on the Las Vegas strip, no issues. I do not loose reception when I park in my garage. The Antenna on the roof has a built in amplifier and the Nav-System is very sensitive. I think yours has a problem!
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
brocksolid
Sep 29, 2015 12:28 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
