no amp needed
Old Jun 1, 2013 | 11:36 PM
Westside_TL's Avatar
no amp needed
if i get a tube like this
Amazon.com: Bazooka BTA10250D BT Series 10-Inch 250-Watt Class D Amplified Tube: Car Electronics Amazon.com: Bazooka BTA10250D BT Series 10-Inch 250-Watt Class D Amplified Tube: Car Electronics
would i still need an amp or one of those amp componets to install?
Old Jun 2, 2013 | 09:46 AM
vivmike's Avatar
No amp needed...it brings it's own. However, you will need a line out converter to run from the stock head unit.
Old Jun 2, 2013 | 09:47 AM
vivmike's Avatar
You may also need to dynamat parts of the trunk.
Old Jun 2, 2013 | 12:36 PM
si1point6's Avatar
No need for a line converter- the powered Bazooka comes with speaker level inputs.
http://a248.e.akamai.net/pix.crutchf...204BTA1025.PDF
Old Jun 2, 2013 | 01:14 PM
if no converter then how would install to radio and also would this be good to replace the stock 8 tired of fixing them
Old Jun 2, 2013 | 04:32 PM
Megatron_79's Avatar
Why do you want this? I figure just upgrading the stock with better grade speakers would make the sound better and clearer,...?
Old Jun 2, 2013 | 05:37 PM
rebmem's Avatar
I just installed a similar powered sub in my 09 TL, the Infinity Basslink. Made a huge improvement.
The Bazooka you are looking at is very similar. The Bazooka manual recommends using the speaker level (high level) for the input. I think you can do like I did and remove your 8 inch sub and extend it's two wires to the Bazooka. You need to run a 12 gauge wire from your battery, with an inline fuse at the battery, to the trunk. Also need a 12 gauge ground wire from the sub to the car body, I connected to the car body under the back seat on the drivers side where there is a factory ground connection.
My Basslink came with a level control that I mounted in the dash so I can change the bass level. It is a phone type cable that plugs into the sub and I ran it forward to the dash next to the 12 gauge power wire. I love this feature. Bazooka sells it optional for your sub ($28).
Old Jun 2, 2013 | 06:25 PM
sounds good and easy, any easy way to get the to the stock sub so i can get the wire? which tube better bazooka or bass link?
Old Jun 3, 2013 | 06:32 AM
did you use the radio fuse as the remote wire?
Old Jun 3, 2013 | 12:11 PM
rebmem's Avatar
The stock sub has a connector (as do all your speakers), you could pull down the trunk liner and unplug the speaker wires from the sub but you still have to lengthen them. You can probably cut off the connector and solder/butt splice wire from inside the trunk. I took out the back seats and rear package tray and permanently removed the stock sub figuring it would leave a sound passageway. I cut off the connector and soldered on some 16 gauge wires (lamp cord) and used heat shrink tubing to insulate. I also replaced the 6.5 inch rear deck speakers with Infinity co-axial's since the OEM's are prone to failure as shown in this forum.
*****The Basslink doesn't need a remote turn on wire, it senses the speaker input feed and turns itself on/off.
I can't say which is better sounding, the Basslink or Bazooka.
The Basslink costs less and includes the remote adjust which people recommend to buy with the Bazooka.
Old Jun 3, 2013 | 02:08 PM
si1point6's Avatar
Don't cut off any more of your factory speaker harness connectors. You can buy and use the speaker adapter that Metra makes (72-7800), and it plugs in directly to the connector on the car's wire harness. And if the attached leads are not long enough on the Metra adapter, you can cut its connectors off and extend the Metra wires. I have used this Metra connector on my front and rear speakers and they work great. It is also the same adapter for the factory 8" sub in the rear deck.
http://www.sonicelectronix.com/item_...a-72-7800.html
Old Jun 3, 2013 | 02:22 PM
rebmem's Avatar
Thanks for that tip and I can understand why people feel that way about cutting the OEM wiring.
I have cut off ALL of mine because I will never use the factory speakers again. I find it easy to cut and solder plus I believe it makes for a clean and very reliable connection. Now on my 1970 Challenger I am with you.....I would never cut the factory wiring.
Another idea I saw on here is to remove the plastic plug recpticle from the OEM speaker being replaced and solder extension wire to that.
Old Jun 3, 2013 | 07:52 PM
thanks ordering now!
Old Jun 3, 2013 | 07:54 PM
thanks for all your help! do you a link for those infinity 6.5?
mada51589
Jan 9, 2025 04:40 PM
AndrewS
19
Mar 14, 2024 06:59 PM
notfast
1/2G MDX (2001-2013)
Mar 28, 2023 08:10 AM
handsom-hustla
Nov 13, 2015 05:04 PM
Soul_Deamon
4G TL Problems & Fixes
Nov 2, 2015 04:32 PM
