will this kill voice comm
Old Jun 1, 2013 | 10:58 PM
Westside_TL's Avatar
on my 07 tl they said (audo shop) that if i added compents to my door speakers that i will lose the mic voice command and center speker. is that true for the 2011 tl tech aswell?
Old Jun 2, 2013 | 09:52 AM
vivmike's Avatar
Compents???
Old Jun 2, 2013 | 10:33 AM
si1point6's Avatar
I have a 2009 Tech, and I have Infinity components that replace the OEM speakers in the front door and a-pillars. I am powering them with an aftermarket amp opposesed to the factory amp, and I still have voice command and center speaker functionality.
Old Jun 2, 2013 | 01:16 PM
yes thats what i told them to do at audio express, they said i would lose center, stock sub and voice mic
Old Jun 2, 2013 | 08:23 PM
sympley's Avatar
sipoint6 how did you connect the amp to the system. What did you use for the signal wires? Do you have the ELS sytems?
Old Jun 4, 2013 | 01:31 AM
si1point6's Avatar
sympley,
My TL came with the ELS system. The aftermarket setup I have is a Clarion EQS746 equalizer and an Alpine PDX-V9 amp. The signal goes into the equalizer first, and then it feeds into the Alpine amp. Both items only take RCA inputs. Since the factory amp (located in the trunk, specifically in the passenger-side quarter panel area) only has speaker wire outputs and not RCA outputs, I had to convert it. Instead of using a line converter, I decided to tap into the speaker wire that comes out of the factory amp and convert it to RCAs using JL Audio XD-CLRAIC2-SW converters. The photo below is one of the adapters I used, and I added the red insulated wire connectors:
http://www.crutchfield.com/p_136XDCL...W.html?tp=2802
The Clarion EQ only requires one set of RCAs (for a total of 2) as an input, and it outputs it into 4 channels to go into an amp. The EQ also has the ability to fade from front to rear.
http://www.amazon.com/gp/product/B000EZV3T8/ref=oh_details_o04_s00_i01?ie=UTF8&psc=1 http://www.amazon.com/gp/product/B000EZV3T8/ref=oh_details_o04_s00_i01?ie=UTF8&psc=1
http://www.clarion.com/us/en/MungoBl...412/EQS746.pdf
Because I decided to install the EQ in the glove box, I tapped into the factory tweeters in the a-pillars instead of tapping into the factory amp in the trunk and running another set of wires down the side of the TL. I added some length of wire to the tapped connection, terminated it to the JL audio wire adapter, and then plugged the RCA into the back of the EQ. I tapped into both the left and right factory tweeters in the a-pillars to get my inputs to the EQ. I then ran 4 RCA cables from the EQ output to the Alpine amp input:
TLguy42
Sep 26, 2015 11:27 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
STL TL-S
Sep 23, 2015 08:52 PM
