? iPod/USB hook-up
Old Aug 29, 2012 | 03:23 AM
Sleeper3.2's Avatar
? iPod/USB hook-up
hi guys it seems the usb /ipod hookup wont work in my car just bought it for 25 with 29k miles on it been figuring everything in the car out but this seems to be the one thing i cant get to work
Old Aug 29, 2012 | 08:14 AM
CerberusKy's Avatar
Plug ipod into USB, make sure power is on, set the stereo to "USB". Should work.
Old Aug 29, 2012 | 01:09 PM
Sleeper3.2's Avatar
how do you set the stereo to usb i cant see usb on the dash when i put it in and when i push aux nothing happens
Old Aug 29, 2012 | 03:20 PM
CerberusKy's Avatar
Sleeper... do you have the tech model? if so you hit the HD/AUX button a couple of time until you see the USB come up on the stereo interface. If you don't have the tech model, I have no idea.
Old Aug 29, 2012 | 07:21 PM
Sleeper3.2's Avatar
its supposed to come up on dash when i start it up but it doesnt
Old Aug 29, 2012 | 10:11 PM
CerberusKy's Avatar
Do you have the Tech model (GPS) or not? If not, I think someone with a non-tech model will chime in.
Old Aug 30, 2012 | 11:05 AM
greatfolded's Avatar
Like CerberusKy said, you may need to cycle through using the HDD button -- it goes between the hard drive, Bluetooth, and iPod, I believe.
Also, if you've paired the device with Bluetooth, Apple has an annoying "feature" to use the last detected connection. So, it's possible that the you're actually connected via Bluetooth, even if the dash says iPod. In that case, you can either change the output on your device, or you can unplug it and plug it in again. Or, you could cycle through with the HDD button until you get to Bluetooth.
I guess if all else fails, make sure that the radio is actually powered on, and that the USB end of the cable is firmly plugged into the USB output of the car.
Old Aug 30, 2012 | 03:57 PM
Sleeper3.2's Avatar
i have none tech will try these ideas and get back to you guys
Old Sep 2, 2012 | 11:43 AM
Sleeper3.2's Avatar
still cant figure it out i have the owners manual and noting in there works to make the usb or ipod work anyone have any more ideas
Old Sep 5, 2012 | 09:10 PM
Ryan Ramkissoon's Avatar
8th Gear
What model iPod are you using?
and what does the iPod display when you plug it in?
have you tried any other things like a USB flash drive to see if anything else works via USB?
Old Sep 8, 2012 | 11:22 AM
Sleeper3.2's Avatar
i am using the iphone 4 with the latest updates on it and yes i have also tried using the usb hookup with flash drive both are no go. nothing displays that they are even hooked up iphone shows nothing when hooked up
Old Sep 11, 2012 | 05:06 PM
sluzynsk's Avatar
It sounds like something is wrong... I would consider a dealership visit.
Old Sep 11, 2012 | 05:16 PM
seohinge's Avatar
5th Gear
get the dealer to replace the usb cable
Old Sep 17, 2012 | 11:55 PM
8th Gear
Any word from the dealer sleeper??
Old Sep 20, 2012 | 11:37 PM
Sleeper3.2's Avatar
hav6t had time but taking it in this week
LIPPSTUH
Socal
529
Oct 27, 2017 06:18 PM
99CL
Apr 5, 2010 07:28 PM
Nov 15, 2008 09:05 PM
Acurate
May 16, 2002 07:04 AM
