iPhone 3G Issue
Old Oct 10, 2008 | 11:35 PM
TLDeac's Avatar
iPhone 3G Issue
Well,
I am loving the new car, but have uncovered a bit of an issue. When plugging my iPhone 3G into the usb port, I got a notification that it will not charge the phone. the iPod function still works, and bluetooth works like a charm.
Unfortunately, not being able to charge the phone while playing it will eat the battery, so I will have to plug in a separate iPod, which kinda defeats the purpose of the iPhone...
hopefully Acura can come up with another cable that will work, but for now this is a bit of a bummer
Old Oct 10, 2008 | 11:39 PM
OGHK87JaY's Avatar
Well couldn't you use the bluetooth? Doesn't the car and Iphone 3G have A2DP?
Old Oct 10, 2008 | 11:49 PM
TLDeac's Avatar
iPhone doesn't work with A2DP, thus the bluetooth audio.
It has been known for months that the iPhone 3G doesn't work with the older cables. It's a shame that they couldn't have changed the spec. Hopefully we can come up with a mod cable if they can't...
Old Oct 10, 2008 | 11:55 PM
OGHK87JaY's Avatar
Oh that sucks I its something acura needs to improve on adding then
Old Oct 11, 2008 | 08:31 AM
GeorgeTSX's Avatar
2004 TSX NAV 5AT MSM
Man that sucks that it won't charge the iPhone 3G. Hopefully Acura will correct that issue. I would go to your dealer and make them aware of that and have them ask Acura if they plan on a fix.
Old Oct 11, 2008 | 08:50 AM
PetesTL's Avatar
My iPhone 3G charges just fine.
Old Oct 11, 2008 | 07:11 PM
TriBruin's Avatar
9th Gear
This really doesn't make any sense. If you are plugging the phone in to the USB port, it should have no problem charging. The 3G only has problems when connected to a cable charging over the Firewire pins.
(Unfortunately, although I have a iPhone 3G, I don't have a 4G TL to test it.)
Old Oct 11, 2008 | 08:46 PM
TLDeac's Avatar
Pete,
When you use the apple cable and plug into the usb port in the console, you do not get a message that the accessory is incompatible with the iPhone3G?
Very curious, I will try with a different cable...
Old Oct 11, 2008 | 10:20 PM
PetesTL's Avatar
Originally Posted by TLDeac
Pete,
No....it charges just fine. (Make sure you're using the right cable and your iPhone has the latest software installed).
Old Oct 11, 2008 | 10:41 PM
xrays's Avatar
When I test drove the 09 TL, I plugged in my iPhone 3G and it charged just fine. The cable was the saleman's that came with his iPod Touch.
Old Oct 11, 2008 | 10:54 PM
TLDeac's Avatar
Hmm
Well,
I read these reply's, grabbed another cable, which I just came from my ipod touch, and when I plug the iPhone 3G in, I get a message "this accessory is not certified with iPhone, would you like to enter Airplane mode to avoid interference"
It shows a charge symbol in the battery icon, but I am not certain it is charging. Is no one with an iPhone 3G getting this message when they plug in?
Perhaps I got the "LT" version of the USB connector
Old Oct 12, 2008 | 06:09 AM
Colin's Avatar
I believe all iPhones offer to turn off the radio to avoid the 'dirka dirka' sound when the phone connects to the signal tower. I have an original iPhone and I get this message. If the big green battery shows on the phone, it is charging.
Old Oct 13, 2008 | 12:49 AM
VelfarreClubber's Avatar
I think its just your car and you should let the dealer know about it, maybe its a bad usb cable that came with the car? worst case scenario you might have to get this https://acurazine.com/forums/showpos...9&postcount=18
posted from this thread
https://acurazine.com/forums/showthr...258&highlight=
good luck
Old Oct 13, 2008 | 12:46 PM
Colin's Avatar
good luck
No, it might have been the first cable, but it sound's like it's fine now
Old Oct 16, 2008 | 10:11 PM
TLDeac's Avatar
I have been traveling this week and haven't had the chance to follow up here.
I tried different cables, and get the same error message. However, I have discovered that the phone does charge and have full ipod functionality.
Unfortunately, there is a buzzing sound when playing audiobooks that is not present when I use other ipods.
I don't know what all of this means, but if no one else is getting the "this accessory not certified for iPhone" message on the phone itself when plugged in, I may have a defective usb connector, or the phone could be bad, although I find either unlikely.
For grins, I did order the power inverter and will try when it arrives.
Old Nov 4, 2008 | 12:52 AM
PaulNY's Avatar
I get the same message with my iPhone 3G, but I assume its normal since i got that message with pretty much every iPhone car audio adapter when I had my Accord. Since Edge horrifically interferes (like the nextels) with car speakers, the airplane mode would presumably reduce most of it. HSPDA (3G) on the other hand has nearly zero interference and works flawlessly despite that message when I plug it into my 09TL.
Old Nov 5, 2008 | 12:11 PM
rhn75's Avatar
2014 MDX Tech / sh-AWD
My cousin has a 2008 Audi A6 and experiences the same issue with his iPhone 3G. I guess this is not an Acura specific issue...
Old Nov 6, 2008 | 11:43 AM
Acurafiend's Avatar
The reason you are getting an incompatible accessory message is to let you know that you may experience static due to your cellular signal. They put this message on the iPhones because when the phone is placed near speakers, or other electronics it can cause static. You will notice that if you are too close to a speaker, the speaker will emit static just before the phone rings. You shouldn't have any problems because unlike your desktop-like ipod speakers where the iPhone would be in close proximity to the actual speakers, your iPhone will probably be in the handy arm rest drawer. When the phone is put into airplane mode it turns off any wireless signals such as wifi, blue tooth, and even your cellular network, eliminating the static issue. You shouldn't have to do that in the car, however, and your phone will charge.
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
Frathora
Sep 28, 2015 11:29 PM
carz0159
Sep 20, 2015 06:11 PM
Barb Jackson
Sep 15, 2015 02:27 PM
IndycarFaster
Sep 11, 2015 02:52 PM
