TL SH-AWD Engine question
I'm new to Honda/Acura and need a little direction. Recently I found a 2012 TL SH-AWD that has 20k on the clock and a rebuilt title. The owner tells me that the car was flooded which is how it got the rebuilt title. He also says that the engine developed a timing problem which required the timing belt to be changed. My question is what could cause the engine's timing to be off at only 20k miles? Also, does the TL SH-AWD have an interference or non-interference engine. I'm getting a good deal price wise and was wondering if anyone could shed a little like on the engine situation.
The engine is an interference motor; if you can have him send any documentation about the repair, it'll help. You can have a compression test to ensure the valves are good, and I'd also recommend a leakdown test as well to make sure you aren't getting into a SH-AWD TL that's going to be consuming oil.
If the car was flooded and water got to the belt, it softened the belt and then when dried up it hardened the belt so much that it probably skipped a tooth, or two, or three. SO the timing went coo-coo. Other parts in that area, such as the tensioner maybe was stuck, etc. Flooded cars are trouble, even if they look fine when you see them up close. Besides, TLs major parts are too expensive to replace or re-build (i.e. engine, transmission, electronics etc) when they break down a year or two after the flood and because of the flood.
Not sure what kind of deal you get because of the re-build title due to flooding, I would paid $1.
Stay away from that car. It is trouble down the road.
Unless it's $5k I'd steer completely away.
Have to agree with Silver and Muffin, with a high mileage well maintained TL you know what you are getting. A flood damaged TL may have underlining issues that mysteriously show up.
If you decide to sell later it may be very difficult since most potential buyers stay clear of salvage titles.
wusty23jd
Sep 24, 2015 11:41 AM
Billu99tl
Sep 13, 2015 11:30 AM
