Taillight busted
Taillight busted
Someone took it upon themselves to either purposely break my passenger side taillight on my '09 SH-AWD. It also could have been a hit and run.
Regardless, the outside lens is all that is broken. Do I need to replace the entire taillight assembly or is it possible to change just the lens?
Also, will water cause an issue if it gathers inside the lens, causing me to need to tape over the hole?
Thanks in advance for your help.
I'm not sure if water or moisture would pose any problems. I recently swapped my tail lights with one of the az members and the procedure was quite easy. Plus I'm not handy at all. It's done by partially removing the fabric panel in the truck and unscrewing some components to get to the electrical wires. you can try Acura of delay online parts store
Iakonafuji
09-21-2015 02:39 PM
