Plasti Dip
Old Feb 12, 2013 | 06:45 AM
bigl27x's Avatar
Plasti Dip
Has anyone use plasti dip on the chrome trims on there TL... I was looking at vinyl overlays but i seems that i have to remeove to trims to have the vinyl wrapped properly and it looks like a pain to do that...
Old Feb 12, 2013 | 07:45 AM
of course it's been done.
plasti-dip is cheap at 7 dollars a can. and can easily be peeled off.
however, there is a learning curve on spraying.
if you've ever done arts and crafts before, you know what I'm talking about. uneven spray patterns and drips can happen.
also, since its easily removable, when removing the painters tape, the plastidip can come up.
So, it takes some practice to get a smooth consistent spray.
From far away, it'll make the trim look AWESOME!!!!
but then as you come closer to the car, you'll see imperfections.
If I had a choice to wrap or plastidip, I'D WRAP IT UP!
I've done my trim on a different car about 8 or 9 times already..
Each time, it gets closer to perfection....but still doesnt come close to a wrap job
Old Feb 12, 2013 | 10:54 AM
potmilkz's Avatar
its a poor mans way to black out shit.. it doesnt last long.
Old Feb 13, 2013 | 12:44 AM
bigl27x's Avatar
guess ill just wrap it up lol
Old Feb 13, 2013 | 08:01 AM
LawnPro's Avatar
Scott
It can't hurt to try the plasti-dip for a cool $7.00? If it looks bad, keep trying and then decide to wrap.
Old Feb 13, 2013 | 08:03 AM
One can is enough to do multiple trims multiple times.
Old Feb 13, 2013 | 09:55 PM
Joseph Chon's Avatar
if you get that done, post pics please
Old Feb 13, 2013 | 10:10 PM
VQPower37's Avatar
im interested to c pics too ... esp close ups, i would like to see the finish
Old Feb 14, 2013 | 09:48 AM
Alexander.'s Avatar
Plastidip has its pros and cons, as justnspace mentioned it all boils down to how well you prep and your experience applying it.
I've done a complete black to white dipped EVO IX and you certainly learn alot - it's a fantastic product when used properly and for the right reasons.
If you were wondering what your trim would look like black and pictures just don't do it for you, it's great to try. I would suggest finding some old chrome or plastic pieces in your garage and working with them first, to learn how to spray it, how it dries, how it finishes, how to mask around it (you don't need to mask the actual item being dipped, just immediately around it).
Biggest tip i could give you is your first coat has to be very light and even, to give the rest of the dip something to adhere to. The following coats need to go on thick almost to the point of running (you need to find that fine line, and only will through experience) otherwise, if you continue light coats you will get a rough finish. Also make sure the nozzle of the can is clean, after every coat turn the can upside down and spray until it comes out clear. If you live in a cold area you will need to warm the can up prior to spraying or it will come out in a nasty stream and ruin everything.
Good luck in your dip goals of 2013
Acura604
2G RDX Photograph Gallery
17
Feb 8, 2021 03:32 PM
Acura604
27
Oct 8, 2020 09:24 PM
Abel
3G TL Photograph Gallery
Sep 22, 2015 10:01 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
02tl-p
Sep 6, 2015 10:28 PM
