Memory settings question
Old Jun 19, 2020 | 02:10 PM
dregsfan's Avatar
This was probably answered somewhere, but I can't find it. When disconnecting, or replacing, the battery, are any memory settings (seat and mirror positions, sound system channels) lost?
Old Jun 19, 2020 | 04:22 PM
Riboflavin's Avatar
Seat and mirror memory is lost, but radio presets, phone contacts, and navigation settings are still saved. Just make sure you have your 6-digit security code to reactivate the system.
Old Jun 19, 2020 | 10:51 PM
dregsfan's Avatar
Thanks. When I have to get a new battery I'll make sure the place uses the device that plugs into a power port to provide power to maintain memory settings. I don't want to lose the seat memory.
Edit: I just googled memory savers, and an article says that cars made within the last 15 years or so have power ports that are only active when the car is running, so the type that plugs into the OBDII connector is needed.
Old Jun 22, 2020 | 05:28 PM
echodigital's Avatar
From TL to RDX
If you leave your set 'as set'. Just hit Set 1 again when you re-connect your battery. The 2nd seat setting will be lost via your second key though...
Jackass
Oct 11, 2019 08:52 AM
CenturionTL
Aug 27, 2017 12:32 PM
stevey678
Mar 13, 2017 12:04 PM
TL-k100guy
Mar 27, 2014 06:35 AM
inazTSX
Oct 31, 2009 02:44 PM
