Memory settings intermittent
Old Mar 3, 2017 | 05:36 PM
stevey678's Avatar
Any idea on how to fix my intermittent memory settings? I have to set my memory settings on the door almost every other day.
Old Mar 3, 2017 | 05:46 PM
guitarplayer16's Avatar
Is it an 04 or early 05?
It's a common problem that the memory seat module located under the front seat were defective and there was a bulletin about this. The fix was to replace the module.
If not, the culprit would be from the side mirror actuators - they act up and lose position which also means that you'd have to set your memory setting every day. The fix would be to replace the mirror actuators.
Old Mar 3, 2017 | 08:55 PM
sockr1's Avatar
Mine is the same way on 08 type s. My memory settings barely ever work
Old Mar 3, 2017 | 09:12 PM
May be a stretch but how oldis your car battery
Old Mar 13, 2017 | 12:04 PM
WDPanda's Avatar
Could this be the mirror memory unit?
38850-SEP-A01 / Memory Unit, Mirror
http://www.acuraoemparts.com/auto-pa...nit-cabin-scat
