Headlight Washer Question
Anyone know if there is a way to stop the headlight washer from going off every time you use your windshield wiper after you start your car? Uses a lot washer fluid lol.
Fog lights don't change whether or not the headlight washer goes off or not. Does pulling the fuse also mean that the headlight washer not work when I push the headlight washer button too?
I've heard a lot people hate headlight washers because they can ruin a perfectly good wash job when you just want to clean something off your windshield.
Pulling the fuse would render the headlight washers useless, they won't work at any time after the fuse is pulled unless you put the fuse back in. When you pull the fuse you're breaking the connection between the motor that runs them and the battery.
Thanks again guys
To turn the headlight washers on demand when the headlights are on. Otherwise the regular windshield wipers activate it when the headlights are on.
The default headlight on system is stupid cause it is assuming we Canadians only turn on windshield wipers to clear snow or slush!
It should just be left to be activated via the dedicated button or maybe a double tap of the regular wipers.
tman570
Jun 11, 2019 07:56 AM
BoricuaTL
Apr 8, 2016 01:08 PM
Marmbo
4G TL Problems & Fixes
Sep 21, 2015 09:39 AM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
