Ebay aftermarket TL headlights
I need a replacement set of aftermarket acura tl headlights I seen the aftermarket ones on ebay wondering if the projectors are the same as in the Oem ones?
http://www.ebay.com/itm/Passenger-Side-Replacement-Head-light-12-12-For-Acura-Tl-33101-TK4-A11-/331119896191?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2012%7CMake%3AAcura%7CModel%3ATL&hash=item4d1848a67f&vxp=mtr
Are the projectors as good tho as oem? I want to get greenkouki to custom shield them and clear lens to make it better, I currently retrofitted with s2000 I don't really like the s2000 within tl
It says they are bixenon aswel so can't be the same projectors
so you have a set of headlights but you dont like how you modified them? you really dont need custom cut off sheild.. i retroed my stock headlights and just swaped out tsx-r and i still get a sharp cut off.. those are not bi-xenons i think its just worded wrong
however, who knows what an aftermarket headlight company found on ebay has put in.
they are not OEM therefore not up to OEM standards.
it could be any lens popped in there, and you wouldnt even know.
if the head lights themselves are not OEM, i wouldnt bother.
I'm not sure about DEPO and what kind of lenses they use, but DEPO's are used as OEM replacement's
I plan to sell my s2000 tl setup and go back to factory with clear lens so I will get my money back, but if none sure if they are as good or same as oem probably wont be best I buy them
acura1983 (03-09-2016)
Yes, I agree an aftermarket projector isn't going to be OEM quality.
The coating on the inside of the projector could be of different quality/color which would change the light output; among other things.
I would think the cutoff shield is identical in shape to the OEM shield and I would also think the projector holds the lens the same way. If this is true you could send them to JNC and have him modify them with custom cutoff shields and TSX-R lenses (which will help your above issues).
justnspace (05-20-2014)
nttstt444 (05-20-2014)
What is it you dont like about the S2k projectors in your headlights?
I bought the eBay depo headlights with the clear corners. They came with clear lenses and 6K bulbs also. I must say that they are just as good if not better than my OEM's with the TSX-r lenses (looks and output). The cut off seems sharper with a blue'r and ultraviolet cut off.
The clear corner to me looks a lot better than simply removing the reflector.
Overall I was very happy and I really cant tell a difference between the oem vs. the depo. The clear plastic is just as good as oem but the black plastic is definitely softer on the depo lights.
rock the block
No but, I might have time this weekend.
Can we see pics of the depo, with clear lens please . S2000 are really good for lower cars I would rather fxr or maybe rx330 for the tl but I can't be bothered il just stick with oem projectors with bixenon mod,
It's very easy to mod the 4th gen tl projectors to do bixenon like the 3rd gen tl projectors
So I plan to go that route with custom curve shield and tsx clear lens
fedcrom (05-21-2014)
The Original Shawdy
Pretty sure they're both the same wheels. Just one is painted black. They are vossens.
adreano17
09-29-2015 08:48 AM
xsilverhawkx
09-28-2015 06:51 PM
