2011 TL 3.7L Engine rattling noise
I have own this 2011 TL SHAWD for half year. The engine has some slightly clicking noise when speeding, and my mechanics told me it should be the noisy valve or lifter, and he put some rislone oil additive and asked me to wait until an oil change. The weather drops cold to 0 degree last night, and I find the engine gets some really loud rattling noise. Is this the same issue from noisy valve or lifter? Or something related to belt tensioner? My mechanic told me to do a valve adjustment if the oil treatment doesn't work. The TL has 180k mile on it.
You have the 3.7L engine which is prone to burning oil. Make sure your oil is at the right level and you are using 5W-20 at a minimum. Many folks who have had issues like yours found the rear cam was worn/toast from oil passages being clogged from carbon deposits from the burning oil.
6G TLX-S
YOUR CAR IS BURNING OIL !
I'm at 92k miles and it drives like an absolute BEAST!
my suggestion would be to try Shell Rotella T6 Full Synthetic 5W-40 Diesel Engine Oil. I am running it in my MDX and engine runs much smoother ....
According to oil test in Europe it is one of the the toughest engine oil, good additives, cleaning properties and handles heat really good..
And it is used in gasoline turbo applications by Subaru, Mitsubishi owners too...
6G TLX-S
It is a norm for European vehicles to burn oil like crazy. But generally, Honda engines (except the 3.7L-V6) are not known for burning oil.
Most Honda owners do not require to add even a single drop of engine oil in between oil changes.
But our 3.7L-V6 on the AWD trim is known to have engine defect that causes oil burning issue.
So always keep an eye on the oil dip stick level, and maintain the oil level at the top (max) marking.
That's definitely the timing belt tensioner. My '09 SH had the EXACT same noise. It would go away after the car warmed up too. There are a few others on here with the same noise and turned out to be the hydraulic timing belt tensioner.
An update on this: the noise is growing loud quickly and go replace the timing belt and tensioners, the noise is gone now. So I think I can conclude it is the tensioner. Mechanics told me they have seen a lot of bad tensioner causing noise on these J engines, seems to be something common.
Though still some noise like diesel engine, but it is like this since I got this TL. Wondering if it is needed to be fixed, feel it maybe normal becuase it is high mileage(185k).
