Xxr 530
Old 03-11-2014 | 09:01 PM
  #2041
2Morrow's Avatar
Driver Mod
Love these wheels, I got a set myself. Look good and easy on the wallet!
Gotta rower your racura now...
Old 03-12-2014 | 02:47 PM
  #2042
sockr1's Avatar
anybody with the +20 setup using a front camber kit?
Old 03-12-2014 | 03:46 PM
  #2043
ultimatum127's Avatar
I have a +20 setup with no front camber kit... haha in the front there is only a .1 degree difference. The problem with my camber is only in the rear it is about .5 degrees different from one side to the other, otherwise the natural camber on our cars is very good.
Old 03-12-2014 | 05:49 PM
  #2044
liwanra's Avatar
Here you go, taking a break from spending money, only 2 weeks in Tein Basis installed and rims..
Old 03-12-2014 | 06:41 PM
  #2045
liwanra's Avatar
Old 03-13-2014 | 12:24 AM
  #2046
rgs1987's Avatar
Wow these wheels were exactly what I was looking for. Lots of info on here. Can't wait to get them.
Old 03-13-2014 | 06:19 AM
  #2047
tihomirbg's Avatar
Originally Posted by liwanra
What lug nuts did u go with?
Old 03-13-2014 | 09:43 AM
  #2048
sockr1's Avatar
anyone with a front camber kit?
i had -1 degrees all around at about 1.3/1.5" drop, but just lowered it to 1.75 all around and my camber went to -1.4 and -1.7 in the front and i kept the rear at -1 in the back (camber kit). my toe was near zero and i had wear from camber in the front at the mild drop.
i have a front camber kit but haven't installed it yet. i'm worried that there isn't enough room to move it back to -1 so i'm looking to see if anyone is already using a front camber kit.
worst case i guess i can install it, get an alignment, and see if it rubs, but would be better if i heard from someone here first
Old 03-13-2014 | 12:31 PM
  #2049
tihomirbg's Avatar
I also have only rear camber kit and also have 1.3-1.5 drop and no camber wear on the tires. I guess i will have to get it aligned once i install my xxr- where do you go for an alignment? Cuz i had places refuse to take me cuz they say that body kit- the car wont be able to get on the ramp
Old 03-13-2014 | 02:15 PM
  #2050
liwanra's Avatar
Standard lugs that it came with ...close ended
tihomirbg (03-14-2014)
Old 03-13-2014 | 03:06 PM
  #2051
sockr1's Avatar
i have a lifetime alignment at firestone. i go to a special firestone that has an in-ground lift
Old 03-14-2014 | 12:43 PM
  #2052
Skyng's Avatar
I ordered a set of 18x8.75 F and 18x9.75 Rear, both +20 offset, but now i need help to decide what tires spec i should get, Does 215/35/18 F and 235/35/18
Rear too crazy to run on? Or should i got 225/40/18 instead?
p.s: and yes, im tucking tires in the back w camber
Old 03-17-2014 | 10:57 AM
  #2053
-sNaFu*'s Avatar
All the world's a stage
I just ordered a set of XXR 530s as well. Quick question. What type of lug nuts and wheel locks are you all using that won't damage the wheels? Also, does it matter what type of hub centric rings to buy i.e. aluminum, plastic, or polycarbonate?
Old 03-17-2014 | 12:58 PM
  #2054
515kbpUA7's Avatar
08 CBP TL-S
oddly enough i ran the oem lugs with my 530's and had no issues
Old 03-17-2014 | 01:56 PM
  #2055
sockr1's Avatar
spline locks, project mu locks, or locks with an internal key. once you go past 25mm in diameter for the lock key then you risk damaging the wheels.
i've always used plastic hubcentric rings
Old 03-17-2014 | 05:29 PM
  #2056
tb330's Avatar
Just ordered a set, tried a couple different places before finally finding them in stock. Ended up spending an extra $50, but at least I know when Ill get them! Looking forward to getting them on!
Old 03-19-2014 | 09:15 PM
  #2057
-sNaFu*'s Avatar
Does it matter the length of the locks too?
Old 03-19-2014 | 09:53 PM
  #2058
sockr1's Avatar
Nope just diameter of key.
Since I'm responding, might as well bump.... anyone running a front camber kit?
Old 03-20-2014 | 01:42 PM
  #2059
NerdO_TL's Avatar
AM FTW!
Im dont have a front camber kit since im low and rub abit when I drive up on driveways, but have rear camber kit so just got to rotate tires every like 5k miles.
Old 03-22-2014 | 10:49 AM
  #2060
Canadian_TLS's Avatar
9th Gear
where would I find a set of 530's with only a 5 x 114 bolt pattern?
Old 03-23-2014 | 12:16 AM
  #2061
pohljm's Avatar
motorsportsR for single drilled
Old 03-23-2014 | 04:22 PM
  #2062
projectwidow's Avatar
I'm assuming if they aren't on their website, that they are out of stock at the moment?
Old 03-24-2014 | 06:17 PM
  #2063
-sNaFu*'s Avatar
Check their EBay store.
Old 03-24-2014 | 07:38 PM
  #2064
Recon_45's Avatar
Just placed an order for these wheels. Ordered 18 x 8.75 +20mm , just hoping everything works out fine
Old 03-25-2014 | 03:07 PM
  #2065
feynman314's Avatar
Where can I find 18x8.75 in hyper silver with single drill? I cant find these anywhere
Old 03-27-2014 | 05:13 PM
  #2066
Future23's Avatar
Will 18x8.75 +20 all around with 235/40/18 rub with a 2" drop? I'm on stock now but plan on lowering.
Old 03-27-2014 | 07:09 PM
  #2067
sockr1's Avatar
Yes if not rolled. Most likely if rolled. Final solution: Get 225 tires
Old 03-29-2014 | 09:23 PM
  #2068
ExonAlbz's Avatar
the site i was going to buy my rims and wheels package don't have 225/40/18s tires only 235/40/18. dammm
Old 03-30-2014 | 03:24 PM
  #2069
feynman314's Avatar
Anybody have pic of a NBP TL with hyper silver 530s??
Still on the fence about buying these. Not crazy about the 10 hole drill and the flatness of where the lugs sit (vs like AG m310s or something). But kind of really want to get these...
Old 03-30-2014 | 03:46 PM
  #2070
pohljm's Avatar
^^ Buy single drilled ones. 10 holes sucks
Old 03-30-2014 | 04:50 PM
  #2071
story.customz's Avatar
I like 10 holes better than single drilled
ExonAlbz (03-30-2014)
Old 03-30-2014 | 05:06 PM
  #2072
ExonAlbz's Avatar
You'll sell them easier too!
Old 03-30-2014 | 10:37 PM
  #2073
SoCalKA9's Avatar
cool.
Old 03-31-2014 | 08:17 AM
  #2074
feynman314's Avatar
Where can you find the single drilled? I emailed nlm and some other place that carried xxr's, but they said they didnt have them.
Id really prefer the single drill. Looks way more betta.
Old 03-31-2014 | 08:25 AM
  #2075
sockr1's Avatar
Really? Read this page before asking
Old 03-31-2014 | 09:25 AM
  #2076
feynman314's Avatar
^^Really. I looked on ebay, emailed motorsportR and nlm and cant find them. I know that you have them from reading the threads. Just looking for a little help. These things obviously arent that easy to track down.
Old 03-31-2014 | 09:45 AM
  #2077
sockr1's Avatar
you emailed motorsportsR and they are the only ones that have ever had them. call them and get a timeline from them on when they will have them in stock
feynman314 (03-31-2014)
Old 03-31-2014 | 01:03 PM
  #2078
feynman314's Avatar
Called and they done even have any in hyper silver...might just have to settle on 10 holes.
Old 03-31-2014 | 09:23 PM
  #2079
NerdO_TL's Avatar
AM FTW!
haha I was going to say that the other day if anybody has hyper silver 530's on a black TL. You should get them! It will look soo clean!
Old 04-01-2014 | 10:20 PM
  #2080
ocdclean's Avatar
8th Gear
Hey guys, been lurking for a while, read through a large portion of this thread and wanted to get opinions on a set of these. You are welcome to quote previous posts if i'm repeating a question.
I have an 06 Base 5at - stock. I plan on doing a slight drop (either Tein H techs, or H&R sports). I'm deciding right now on offset +20 or +33 with the 18x8.75's? This is my daily driver so i'd like to keep everything as practical (but sexy) as possible. I definitely dig the looks of +20 more, but would rather not have to deal with rolling the fenders if I can. Also, what tire should I go with? I've seen alot of 225/40, and 235/40. I live in Idaho so i'd like to protect the wheels as much as possible. Thanks guys
Quick Reply: Xxr 530
