Winter Tire pressure....
So recently I have put some Blizzak WS50's (235/45/17) on to get ready for winter. The shop installed them for me. Just yesturday, the TMPS error went on and told me my front right tire pressure was too low. So I adjusted it, I put in some air for all the tires so it follows what the manual says (240/230 kPa front, 220kPa rear).
Actually, the reading on my dash says Front: L:235 R:235 Rear L:220 R:235
Those are the approximate numbers, cuz some how they keep changing as I drive. But anyway, back to my main point. Should I fix the two front and rear right cuz they have the same pressure? And I realize the car feel very very slippery in the rain. Before, it didn't feel as slippery, but today, I went in a parking lot and tried to test the grip (did that hard sway left hard sway right thing) and the rear kept swinging out and VSA kept flashing. Is that normal?
Also, I went on the highway today and it made ALOT of noise. The tires sounded like they're understress or something. It's almost like, rolling hard rubber on asphault. Maybe tire pressure is too high for the tires causing them to be too hard?
Well, I followed what the manual said. We should be the same right?
So should it be softer front harder rear or the other way around?
94 DC4 RS LSV/Turbo
I just ignore it and put the same amount on all 4 tires some have found that 35psi all the way around works... others like 34psi... currently I am at 34psi and there is some sidewall softness but it adds to the grip
my friend who works at a tire shop said do 32front 30rear since you need the winter tire to spread for more traction
Thanks for the info....
I went with 35psi also, but I don't know. The wheels feel quite hard. And it handles like a POS, major understeer. And when I say major, I mean major.
I'm planning on putting in lower pressure. Around 32 like you said.
I made a mistake, they're WS60's but I guess they're pretty much the same other than the threads?
And I'll try that 35F 32R, thanks for the help Simba. I guess I did choose a too hardcore winter tire.
2005 Acura TL
Unofficial Goat
1 thing you must consider is the temperature your setting the tires at, a 10f change in temp will drop the pressure 1-2psi, so when you set them to 35f32r and it gets cold your tires could become drastically under inflated. I set mine at a 0c cold tire temp and assumed an average ambient temperature of -5c for the current month so I made a compensation and went up 2psi in each tire. You will more than likely need to adjust tire temp in the winter more frequently due to the wild swings in ambient air temp.
Well, I set it to what the manual said after the car was sitting on the street for 5 hours.
Today, I went on the highway for a bit, and the front tire readings went all the way to 250kPa..."36psi"...
is that normal?
The car feels extremely scary going 100km/h too, feels like a feather, almost like the rear wants the break loose.
is that normal?
is that normal?
is that normal?
