What are the advantages/disadvantages of multiple piece rims? (2 piece, 3 piece, etc)
So that if you bend the lip, you can just replace the hoop, versus buying a whole new wheel.
Also 3 peice wheels are generally forged where as a lot of 1 piece wheels are usually cast.
DIsadvantage is that they cost much more per wheel.
Originally Posted by ndx2
multipiece wheels are usually a lot lighter in weight
A caveat for those unexperienced with 3 pc wheels with a reversed rim config, water can collect behind the face of the wheel and later leak out. So after washing your car, you'll need to get behind the wheel's face and dry the water sitting on the inside rim/drop area. The wheels look bitchin and all, but by no means low maintenance. I'll post a picture once I get one for the "thousand words" to better explain where the water sits. Hasta.
How much extra work are we talking
Here's an image of the backside where water can collect.
I dont mind a little extra time (i.e. 5 minutes) to dry the wheels after a wash but sometimes I like to wash and run. Dont usually camp out at each tire everytime I wash the car. On the weekends is one thing, but that mid-week quick wash is another story.
Would you recommend me staying away from the 3 pc if I typically dont have the time to spend on thoroughly drying the wheels?
use a leaf blower to dry 'em. no need to sit and dry each wheel with a cloth. i know some people who actually dry their entire car with a leaf blower. works like magic, apparently.
Indeed it does...especially if you have used multi applications of Zaino or any other high end product. The water literally flies off the car. I use a blower and the car is dried in a matter of minutes. I then use a cloth to get in all the nooks and crannies. Let me say...when its a sunny and humid day...drying a car in minutes as opposed to a hand dry that takes about a half hour is just plain smart....no matter how crazy you may look to your neighbors with a leaf blower to your car.
A major advantage for manufacturers with a multi-piece wheel is the ability to manufacture one wheel center for countless fitments, including widths, offsets, lug spacing, and center bore. All that needs to be changed to accomodate these are the rim sections and post-machining. A one-piece wheel usually only has as many fitments as there are lug patterns, as offset and width cannot be easily changed.
Additionally, using a standard center design allows the wheels to be forged much cheaper, as only one forging die needs to be made to produce all combinations. A forged one-piece wheel is often so expensive because each fitment requires its own die. Casting different fitments is much cheaper, as dies do not need to be made for the investment casting that wheels usually involve.
This is what enables HRE and iForged to stay in business. Effectively, their custom wheels are just custom wheel assemblies. They take their standard center, bore the proper mounting holes, and assemble it with different rim sections. And charge exhorbitant prices.
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
advantage, advantages, bore, center, disadvantage, disadvantages, forged, leak, multi, piece, rim, rims, twopiece, wheel, wheels
