TPMS removal?
I had mine removed with out dismount the tire from the rim. You will still require a shop do it as the need to deflate the tire remove the TPMS and replace it with a regular valve stem.
Pretty much the same process as removing the tires.
It's my understanding that if you do not reinstall the TPMS, your idiot light will stay on in your dash. Why not get new shoes with TPMS?
Since over 95% of the aftermarket wheels won't fit a TL-S due to clearance problems with the Brembos, it shouldn't be hard to do. It's a good safety feature to have IMO.
Just to clarify, the stock TPMS can be removed from the stock wheels and put on aftermarket wheels? Im planning on putting them on my volk wheels. im getting tired of seeing that warning light.
OMGWTF4THGENTL
Yes...
But you're gonna pay a shop to $75-$100 to dismount your stock tires, remove TPMS, install rubber valves, remount and rebalance your stock wheels.
Why not pay $140 for 4 brand new sensors to be installed in your new wheels? Then you're stock wheels are interchangeable...
Feenin on some 20's
soooo. I was being stupid when I installed my TE's w/o thinking about TPMS sensors.....
Now, they are installed and don't feel like taking my wheels to the shop and then have them redo it all over again so I was wondering if there's any way I can take that TPMS light out?? Is there like a fuse or wire or anything to disable the TPMS light from coming on?
Originally Posted by izmyttz
i bought new TPS sensors..how do i get my car to recognize them when i get them in my new wheels?
Wait..... Acura told me to install new TPMS sensors it will be 700 dollars PER SENSOR!
so now im driving around with my idiot light on....
Edit: Got new rims and wanted the damn light and error message to go away, and theyre like "oh we have to get you new ones, $700 per sensor
so should i jsut take out my OEM sensors and put them on my new rims?
i bought a set of 4 on ebay for 135.00 total...screw the stealership..buy from ebay!
Alright so all i have to do is buy 4 new sensors and have those installed and they'll work perfectly fine?!
Are there different sensor sizes and stuff or is it a one size fits all kinda deal?
i ordered these...i will get them in and send them to the guys at the wheel place to have them installed..if you want..you could wait to i get mine and try them out...make sure they work before we both blow 135.00 on tpms that don't work! lol I hope they work..would make my life less stressful
AirJordan you pushin an 04 TL right??? 04 did not come with TPMS, so then yeah it will cost you a pretty penny because you need the sensor, receivers, transmitters, terminal....
The TPMS will automaticlaly readjust pressures and reactivate itself once you get the rolling on the new Sensors, it will show 59psi in the beginning but then drop back down to what the actual pressure is after a few miles.
i just talked to my homie who works at the dealer and says that TSX TPMS are not the same.
I just need confirmation right now that the MDX/RDX TPMS will fit on the TL-s..
can anybody confirm?
Originally Posted by as2222
can anybody help me on this matter?
--->http://www.hondacuraworld.com/Mercha...=06421-S3V-A04
Just confirmed they work fine on 07 Type-S this afternoon.
well, having a variety is good.
Our sensors our $40 a piece.
the other sensors are cheaper than that and ebay has a lot of TPMS sensors availalbe also for a lower cost.
My friend's dealership is out of stock right now so i'm just looking for alternatives.
I found a deal for 4 @ $80 shipped but it's for the 07+ MDX
and nah I have an 08 TL- Type S
neuronbob
23
07-16-2019 10:48 AM
dainmezron
10-16-2015 06:56 PM
