The pictures below probably indicate an obvious answer to my TPMS yellow error message popping up on my computer display but here goes: just to confirm would the right rear TPMS sensor be causing the issue? I’ve watched the other 3 tires increase in pressure real-time while the “58” stays at 58. If it is the sensor is there a recommendation for a quality replacement? Aftermarket or go for OEM from somewhere like Delray Acura out of Florida? Thanks in advance!
I can observe all tire pressures increase from cold. The right rear stays at 58 PSI all the time. I’ve measured it and it’s really 32 PSI cold...
Irritating yellow error screen pops up anytime—4 miles or 25 miles.
What the tire pressure looks like after clearing the yellow screen (but a small message “TPMS” appears on the left side of the instrument cluster).
Mine does the same thing, I finally figured out it was the drivers side front one which also displays 58 when the others are low 30s, then after a while defaults all corners to --.
In my situation I bought a simple eBay one that is within the frequency of the other TPMS sensors as the 07 TL-S doesn't require programming of the sensor, I'll be putting it on in a day or two with my new tires so I'll let you know how that goes. I believe 06-08 doesn't require programming, but anything 05 and older does require special programming, so keep that in mind.
