TPMS and 19's
TPMS and 19's
What up everybody.
I tried to search but was unable to find the info i needed.
I just bought a set of 19's for my 07 WDP TL. I bought a new set of TPMS sensors from the dealer but they wont fit with my wheels. Is there any way of clearing the error code so there is not a light on the dash?
Thanks for your help.
Bone stock tl-s
i had the same issue as you i had the tire/wheel shop install the sensors with a strap on the inside barrel of the rim. they told me they do this alot cuz most new cars have these systems in them. i have no problems at all. i dont think there's a way to dissable the warning light on the dash
Bone stock tl-s
Originally Posted by NCSU TL
what wheel shop did you go to to install the straps and sensors, I cannot find one that even really knows what I'm talking about or have the equipment too,
Originally Posted by Kennedy
You can get the strap kits from discount tire direct for about $40.
I have actually called three times, the first time they had them but I didn't order them because I was going to see if somewhere local had them first or anywhere else might of had them cheaper. Then when I called back to order them they said they didn't have em and I tried one more time and got the same response.
OMGWTF4THGENTL
Originally Posted by Fulani has a TL
Weird I got 19" Axis Milanos wrapped in 245/35/19 and had no problem with the TPMS. I guess I am lucky
My Volk Racing GT-S's (2 piece) are enroute, clearing customs today. I plan to photograph WHY you need these bands to mount the sensors.
It's not luck, it's wheel choice. 2 piece wheels are incompatible with face/stem mounted TPMS sensors as the aire valve is in the center of the barrel, not on the face like common cast wheels.
I have 19s and I had them take my factory TPMS out and put them in and it works fine....I only had that HORRIBLE error when I switched tires and rims and didnt have the TPMS in yet..
Originally Posted by johnbrown
What up everybody.
The posotion of the valve stem on my wheels made the TPMS system not fit. With the straps they fit but I got over the putting the straps on because I figured out that I would need them after I had the tires mounted so I just clear the error on the system every time I start the car.
Thanks for all of your input and support. This forum is the shit.
My first Avatar....
Don't want to hijack the thread but - Does anyone know the correct part number for the TPMS sensor for the 06 TL? I have #06421-S3V-A04 as being the correct number, but there are some folks out there selling #06421-S3V-A03 as the part. Is there a difference?
Come on Kennedy, enlighten me.
thanks
thanks
OMGWTF4THGENTL
thanks
thanks
My first Avatar....
Outstanding! Thank you Sir. Some how, I knew you'd come through.
neuronbob
23
07-16-2019 10:48 AM
