Steering wheel shakes at 65+mph
Old 08-20-2017, 11:53 AM
8th Gear
rharal's Avatar
I got new tires and had the balance them. Steering wheel still had a shake to it. had them rebalance them and still was there. Went back a 3rd time and they replaced the front tires, and it is still there. Not a bent rim, not a balance issue and wouldnt think it would be the tires since they put new ones on.
Any ideas?
Old 08-20-2017, 01:38 PM
Andrew
VisualEchos's Avatar
It's tires 98% of the time, and a lot of people fight with it because it's usually when they think they have great tires. May I ask what make and model of tire you are running?
The other 2% is going to be a stuck brake caliper, and even a small stick can cause big vibrations. Do you smell brakes when you stop from going highway speeds?
My guess is that, new tires or not, it's a tire issue.
Old 08-20-2017, 01:42 PM
8th Gear
rharal's Avatar
kumho ecsta asx tires. I had the same type on there for over 2 years. Had the fronts replaced 3 weeks ago. then had the replaced about 2 days ago with the same brand and model.
Old 08-20-2017, 02:29 PM
BROlando's Avatar
Received 1,170 Likes on 880 Posts
Worn upper ball joints or damaged/pitted axles can cause shaking.
Does the shake get better/worse/no change when the brakes or accelerator is applied?
Old 08-20-2017, 02:42 PM
8th Gear
rharal's Avatar
No change. Could it be a front wheel bearing?, there is a small whine, can't really hear it though.
Old 08-20-2017, 03:12 PM
BROlando's Avatar
Have someone inspect the car for loose components. Could be millions of things.
Old 08-20-2017, 03:52 PM
Andrew
I wish you had a Winter set, just to test it. Got any TL friends around that you can swap wheel/tire combo's with? It's a half-hour endeavor, and will let you know for sure that it's not the tires. Not really a fan of Kumho myself, unless you're getting the HTR-Z, super cheap tire.
Old 08-20-2017, 04:35 PM
8th Gear
rharal's Avatar
i don't have someone i can swap with. Think i'm gonna go have it checked out and if they cant find anything then imma go back to discount and tell them and i'm sure they will hook me up with some new tires.
Old 08-21-2017, 07:17 AM
Turbonut's Avatar
Have them balance the wheel/tire, then rotate the assembly 180 degrees and spin again, should be perfect. If not, machine out of spec or center wheel hole compromised. I need to use the lug hole adapter plate on the balancer on our '04 when I balance them to get them perfect.
Before I got a balancer, I used the Hunter Road Force, but also needed the lug hole adapter plate to get the balance perfect.
GSP9700 Locator
Old 08-21-2017, 08:19 AM
DMZ
Head a da Family
DMZ's Avatar
Were the lug nuts tightened to 80 ft-lbs last time the wheels were installed? Overtghtening with the air gun can cause the rotors to warp causing the very vibration you're experiencing.
Old 08-21-2017, 03:19 PM
8th Gear
rharal's Avatar
Had is checked out and they said it was the motor mounts. I also noticed that when brake sometimes there is a slight vibration. I had the motor mounts replaced about a year ago and i don't think that that's the problem.
Old 08-21-2017, 04:10 PM
Andrew
Interesting.
Old 08-22-2017, 12:49 PM
8th Gear
rharal's Avatar
Ok, so last night i went and bought some new front rotors and pads and put those on real quick and it seems like the problem is fixed. The old rotors and pads were less than a year old also, one must've been warped or something. Thanks for all the help guys.
Old 08-23-2017, 12:24 PM
Sandan's Avatar
U also forgot to mention that when you gently applied the brakes there was a slight pulsating feeling on the brake pedal, this is an obvious sign of wrapped brake rotors.....
sandan
Old 08-23-2017, 03:58 PM
Turbonut's Avatar
sandan
Brake rotors don't warp and personally, every vibration I've experienced in the upper MPH range has been related to wheel/tire problems.
Old 09-10-2017, 04:23 AM
FutureITR's Avatar
Rebalance your wheels.
Old 09-10-2017, 04:24 AM
FutureITR's Avatar
It could be wheel bearing. That's a common issue when things shake at higher speed.
Old 09-20-2017, 09:09 AM
DMC12's Avatar
Really random question, but do you know if when they mounted the new tires they also changed the rim position? I had this happen once and it turned out that one of the rims I had in the back was actually bent and when the rim rotated up from with the mounting of the new tires I got a shake in the steering wheel that wasn't from the tire or weights.
Not sure how bad the shake in the wheel is, but something else to consider.
