Rubbing problem
Rubbing problem
I am having a rubbing issue with my tires in the rear. I just got 18 x 7.5 racing hart c2's with 225/40/18 kumho 712's with a +45 offset. what are my options in solving the rubbing in the rear? it only rubs when i take turns semi-hard.
you need to cut the bumper tabs... that will more than likely be the problem. im not sure exactly where the tabs are located, but if u can get a few people to sit in your car to bring the back down a bit more to where it rubs, im sure you will be able to see it. you can probably cut it off with a butter knife.
yea more than likely just the rear tabs.
USMC Butterbars
Originally posted by GOT PSI?
The RH C2 Evo 18x7.5 only come in +42 offset. If you're lowered, you may need to roll the fenders?
line the fender lip with some masking tape and drive, hitting some dip and bumps. look for the rub marks. IF your offset is +45 you should just need to trim some of the plastic... real easy. just repeat, masking tape, drive, dremel until no more rubbing. finish the cuts with a utility knife. if you see rubbing on the masking tape covering the metal lip of the fender, then you will have to roll it.
SidhuSaaB
05-30-2020 12:40 AM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
