Ride quality........
I am an Acura enthusist since I purchased my first 05` Acura TL w/ Nav. The only issue I have is the ride quality. My wife's Toyota Camry ride smooth as butter and I wanted to hear from everyone on ways to improve the ride quality. I'm not looking to lower the car either....I had that on previous cars and loves the handling but not the ride. My first post so please be gentle. Any suggestions?
Check that shocks and springs are in good condition. Check tires for wear, balance, and proper inflation (32 lbs if OE spec, iirc).
If all is good, then maybe consider switching to '07/'08 base (NOT Type-S) springs/shocks. They are softer than previous model years.
TL has a little more sporting character than a Camry, you might never end up where you're trying to go.
BTW - I *assume* you have an auto (5AT)?
Thanks Bearcat....Yes I have an auto (5AT). I do understand I will never have the same ride quality although would love to reduce some of the harsh bumps on some of the roads in NJ. Also I am running at abut 80k miles so I am preparing for new shocks for around 100k.
The TL's suspension has been tuned with an emphasis on ride comfort while maintaining excellent handling. Thus, the hollow front stabilizer bar is 27.2 mm. Also, the front spring rate has been reduced by 7-percent. The front compliance bushing and dampers are re-tuned for ride comfort, without increased roll and only a slight decrease in performance during instrumented handling tests.
http://www.hondanews.com/categories/735/releases/4213
http://www.hondanews.com/archives/acura
What tire is your TL running?
The quickest way to alter the ride, after air pressure, is to change over to a "Touring" tire rather than UHP tires (i.e. Michelin MXM- stock TL w/Navi tire, Yokohama AVIDs, etc. You might even try an HR or VR tire if the tire store is willing to mount those
The only way to make sure you are getting the 2008 parts is to check the part numbers, if you are inclined to start switching out springs, etc.
I had a Camry (returned gift by my father after he stopped driving), have rented Camrys and have brothers-in-law whose Camrys I have driven-- non-SE Camry suspensions are way too soft for me. However, the '04-06 TL does have a suspension that feels stiffer than most of its FWD peers, which is probably the reason it was the highest-rated or lone FWD sedan in various sports sedan comparisons.
). The only way to make sure you are getting the 2008 parts is to check the part numbers, if you are inclined to start switching out springs, etc.
neuronbob
23
Jul 16, 2019 10:48 AM
emailnatec
29
Sep 28, 2018 04:27 PM
4drviper
Sep 23, 2015 07:42 PM
