Replacement Spring/coil question
Old 04-14-2019, 05:20 PM
3rd Gear
Recolations's Avatar
So I have coils on my car already, I don't necessarily dislike them, but the ride comfort just isn't even remotely there, even after adjusting the dampening screw. Along with a pretty intense rattle from the front and won't hold an alignment.I really would love to swap to a-spec springs, but can't seem to find any since they were discontinued. If I was to change over to springs again( I don't have the car lowered, bought it with coils on it already) mainly going for comfort but a bit firmer than stock, what should I go with? or should I buy a better set of coils?
Old 04-15-2019, 12:25 AM
BROlando's Avatar
Received 1,171 Likes on 881 Posts
I would buy a nice set of coilovers and set them up properly.
But it would help to know what is on the car currently and what you've tried to do to make them work.
Old 05-02-2019, 01:18 PM
JMiles_T's Avatar
If you want ride comfort, one of the most critical components is your choice of tire. It will be a cheaper investment than shocks & springs and it may alleviate your discomfort without you having to spend money on the more expensive parts.
I use General G-Max AS-05 tires at stock size.
DMZ (05-02-2019)
Old 05-02-2019, 02:27 PM
DMZ
Head a da Family
DMZ's Avatar
Old 05-05-2019, 02:41 PM
JMiles_T's Avatar
Originally Posted by DMZ
It was per your recommendation that I got these, so thank you.
https://acurazine.com/forums/3g-tl-t...x-05-a-962925/
I was running Continental DWS tires before these and the ride comfort on them was not good.
Old 05-11-2019, 08:07 PM
csmeance's Avatar
Received 1,991 Likes on 1,414 Posts
coil-overs come in a lot of flavors and with there being so many parts that can be customized it's hard to say do X, Y and Z to fix the issue. You'll need to raise the suspension up and soften the rebound and compression settings if it's too harsh over bumps. BUT If the springs are too stiff and the shocks are too soft the car will feel bouncy and harsh. If springs are too soft and shocks are too soft, car will feel very uncontrolled over large bumps and dips.
Your car not holding alignment and making noise is a issue that needs to be dealt with. It could be a blow coil-over or a bad one on your car causing the issue. Get that fixed first! It could be bad compliance bushings, bad ball joints, bad sway bar links, etc.
TribedazeRDX
03-21-2021 05:56 PM
RONE
06-24-2018 09:24 PM
05TL10-12
05-17-2014 03:30 AM
justifythegame
10-25-2006 03:55 PM
Blazin_TL
05-04-2006 11:28 PM
Quick Reply: Replacement Spring/coil question
