Replacement Spring/coil question
So I have coils on my car already, I don't necessarily dislike them, but the ride comfort just isn't even remotely there, even after adjusting the dampening screw. Along with a pretty intense rattle from the front and won't hold an alignment.I really would love to swap to a-spec springs, but can't seem to find any since they were discontinued. If I was to change over to springs again( I don't have the car lowered, bought it with coils on it already) mainly going for comfort but a bit firmer than stock, what should I go with? or should I buy a better set of coils?
I would buy a nice set of coilovers and set them up properly.
But it would help to know what is on the car currently and what you've tried to do to make them work. |
If you want ride comfort, one of the most critical components is your choice of tire. It will be a cheaper investment than shocks & springs and it may alleviate your discomfort without you having to spend money on the more expensive parts.
I use General G-Max AS-05 tires at stock size. |
Originally Posted by JMiles_T
(Post 16420380)
Originally Posted by DMZ
(Post 16420426)
......................:thumbsup: :thumbsup:
. . https://acurazine.com/forums/3g-tl-t...x-05-a-962925/ I was running Continental DWS tires before these and the ride comfort on them was not good. |
Originally Posted by Recolations
(Post 16411302)
Your car not holding alignment and making noise is a issue that needs to be dealt with. It could be a blow coil-over or a bad one on your car causing the issue. Get that fixed first! It could be bad compliance bushings, bad ball joints, bad sway bar links, etc. |
