Proteg lug nuts
Old Jun 19, 2018 | 02:19 PM
Wdp_3g's Avatar
Proteg lug nuts
Has anyone used these? I was looking at a set for my car but I can’t find any information on them anywhere.
https://www.endlessrpm.com/proteg-lug-nuts/
Old Jun 19, 2018 | 02:27 PM
Bruce is a well respected member of the community! He wouldnt sell bad products.
Old Jun 19, 2018 | 03:21 PM
90foxnotch's Avatar
Looks like a great deal to me, I need some for my new wheels eventually!
Old Jun 19, 2018 | 03:36 PM
TacoBello's Avatar
At that price point, you really can't go wrong!
Old Jun 19, 2018 | 05:23 PM
BROlando's Avatar
As long as you're not using them on stock wheels and will vow to always use a torque wrench and be careful, you *should* be fine.
Old Jun 25, 2018 | 08:43 PM
90foxnotch's Avatar
They make the wheels pop out a little more and don’t stick out too far
I messaged the seller and wasn’t sure if they’d work on the xxrs I want but they work for stock wheels. I thought they might be Ricey and I’m not a fan of colored accessories but o well for the price I like them
Old Jun 25, 2018 | 08:46 PM
Wdp_3g's Avatar
thank you I might have to message or look for other lug nuts because I have Konig wheels but I will probably try these since they are on sale and they should work I don’t think different wheels would change anyth
Old Jun 25, 2018 | 08:48 PM
90foxnotch's Avatar
Yeah these did not fit my xxr wheel. I did not have the special socket but wrapped them in tape but some of the finish on the edges still came off. My moteki sr48s would’ve worked. Their coloring wore off a bit also though
Old Jun 25, 2018 | 08:49 PM
Wdp_3g's Avatar
what made them not work?
Old Jun 25, 2018 | 08:56 PM
90foxnotch's Avatar
They were too big for the xxr I’ll need skinny tuner style llugs. They might fit your brand though
Old Jun 25, 2018 | 11:33 PM
BROlando's Avatar
But...they don't work on stock wheels....
Stock wheels have a "ball" lug seat style. That's quite dangerous...especially with aluminum lug nuts...
Old Jun 26, 2018 | 08:37 AM
90foxnotch's Avatar
Brolando thanks for the information. If that's the case I might switch back to stock. There wasn't a lot of specs on these and I usually over research all purchases before I just buy them. I might just donate them to a local car buddy or something. Its been a couple hundred miles since I put them on and they are all still tight.
Old Jun 26, 2018 | 09:56 AM
guitarplayer16's Avatar
6 days later...
The only way you could use tuner seat lugs on stock wheels is using an adaptor washer.
XXRs you need spline drive lug nuts. I've seen Konigs needing spline drive lug nuts also, but varies by model.
Old Jun 26, 2018 | 10:18 AM
90foxnotch's Avatar
I would not have bought these before if I did my proper research then but OP you just have to find out what style your aftermarket wheels are and go from there. Sorry for accidentally hijacking your thread
Old Jun 26, 2018 | 11:49 AM
BROlando's Avatar
Its a common mistake. Honda uses an unusual lug seat.
The danger is that you're only using a very very small portion of the lugnut cone to actually clamp the wheel. So about 100% of the time, something ends up getting damaged.
Sometimes, the aluminum on the lugnut will deform, fold over, and then damage the lug on the way out. If you're lucky, this will happen to a rear lug stud, which is easily replaced.
Other times, the wheel will work its way loose when driving. This is exaggerated with aluminum lugnuts because they're soft...and because aluminum against steel requires modified torque value due to friction increase in the threads.
Without boring y'all to death....use only ball seat lugnuts for OEM TL wheels.
Old Jun 26, 2018 | 12:00 PM
90foxnotch's Avatar
Thank you BRO. Im ordering a different set Friday that are for Honda wheels. Ive learned a lot while on this site
Old Jun 26, 2018 | 12:11 PM
BROlando's Avatar
No worries!. PM me if u want. I was able to find a decent set of black lugnuts meant for OEM wheels. I think they might be available in other colours.
Old Jun 26, 2018 | 12:42 PM
Wdp_3g's Avatar
How can I tell which will work these are my wheelsif it helps any
https://konigwheels.com/wheels/main-...els/oversteer/
and thanks for all the help I do not know anything about lug nuts I have always just re used stock ones but I don’t want the chrome
Old Jun 26, 2018 | 01:34 PM
90foxnotch's Avatar
So I looked at that link and it says they recommend a spline drive tuner style/ conical seat lug nut. So I would not recommend the protegs. Search for a spline drive conical seat 12x1.5
Old Jun 26, 2018 | 05:32 PM
BROlando's Avatar
A safe bet for most aftermarket wheels is either spline drive or 17mm hex. I prefer the look and function of 17mm hex (Muteki SR35's are cheap and pretty good quality).
Match the lugnut seat to the wheel seat. Most aftermarket wheels have a (60 degree?) conical seat.
If you're not entirely dedicated to taking really particular care of your lug nuts....don't buy aluminum. If you go to a service station/tyre shop for wheel service...definitely don't buy aluminum.
Buy steel CLOSED END lug nuts. Keep it simple.
Old Jun 26, 2018 | 05:43 PM
BROlando's Avatar
To make it simple.
For the wheels you linked...
What u need:
  • M12 x 1.5 thread size
  • Cone seat
  • 17mm hex OR small diameter spline drive
What I recommend:
  • steel construction
  • closed end
  • 17mm hex
  • muteki sr35
Old Jun 26, 2018 | 08:22 PM
Slpr04UA6's Avatar
-------Tim-------
Brolando, could you list that link for the OEM type lugs, that you purchased? I would prefer a different color, oem color if possible....Thnks in advance!
Old Jun 26, 2018 | 09:41 PM
BROlando's Avatar
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F16 0983208468
Old Jun 26, 2018 | 09:53 PM
Search up "ball honda lug nut" on eBay, they've been around for years but the major complaint with the coloured ones were that the finish would chip off/scratch off easily.
I'm not sure if that's changed or not over the years.
If you're looking for OEM-ish lug nuts, I'd check out Gorilla lug nuts. I believe they have chrome and black, not certain on black though.
Old Jun 27, 2018 | 07:04 AM
BROlando's Avatar
I have gorilla's black wheel lock set also.
the black lugs I linked seem to have a decent finish. I've had mine on/off a few times with an impact, and they're mostly fine.
They're also $20something. Even if you had to replace every year or 2...whatever
Old Jul 3, 2018 | 02:48 PM
90foxnotch's Avatar
So I do not want to bash a brand or seller, Bruce has been very helpful and great with previous purchases but the Aluminum Proteg lug nuts are junk. I recently swapped them for the proper ball seat steel lug nuts. Not sure if my studs were bad before but now two have to be replaced because two aluminum ones had serious issues coming off the stock wheels. I highly recommend getting steel lugs as I will be doing from now on when I go to purchase ones for my aftermarket wheels. Im sure if you buy the steel kind from Proteg they will be fine but even the color came off in areas after the second use. Just thought Id give an update. Again this does not reflect the seller-Thanks
ABP UA6
Sep 27, 2017 09:14 PM
Soyboy26
Sep 24, 2011 05:21 PM
kyle77777
May 16, 2010 10:59 PM
ronrecr
Apr 1, 2005 05:43 AM
ronrecr
Mar 31, 2005 10:30 PM
