Progress RSB on 04 5at
I bought a progress RSB recently and it's being shipped. I HAVE google this already but didn't really find an answer. Do I "need" to get end links? I can get some Moog endlinks before the bar gets here. Will stocks be fine or should I upgrade. Car has 133k miles on stock bar. Pros and cons?
110k on my car when I put the Progress RSB in. I'm using BC coils and lowered about 1.5~2in. I used the stock endlinks and have the bar set on the softer setting. No issues.
Head a da Family
Hope this helps.
You should consider replacing those end links at the same time, preferably with OEM's as the Moogs will require regular greasing. I got 5 years out of mine and have replaced them twice. Also, you might want to check the brackets that the end links connect to. I have the CT-Engineering sway bar (22 mm) and those brackets got torn to shreds at age 10 due to the increased strain a thicker sway bar puts on them.
Hope this helps.
Hope this helps.
Yes you can add pre load to it but that's for race car applications that mostly go round and round.
TL BPJ
08-25-2014 10:50 PM
aragrev7
09-09-2011 01:40 AM
Coebee
07-30-2008 12:39 PM
amadeus303
12-02-2005 04:02 PM
