Open End vs. Closed End Lock Lugs
I've been trolling around looking for information on lock lugs with very little luck. I've seen what everyone has been using but haven't seen anyone using open end lugs. Is there a reason for this? I would think they are more secure since the spline style allow for a standard socket to fit over the lock.
The open style requires a hex type tool or key to release which I think is much more rare but I could be wrong. It also provides a uniform look since they are all the same style. Here is an example of the open end:
http://cgi.ebay.com/ebaymotors/TUNER...item1c1bf83baf
Are the "keys" to these open end style lugs not as secure or is there another reason I haven't seen them used?
Back From The dead
The biggest problem with open end is the rust.
I ordered these last night. They are made by Gorilla Automotive and Summit states they are not open end design. I'll take pics when they come in. It would be nice if they were closed (halfway down), so no rust, and have the security of open end hex style lugs. They also look like they actually have a key and not just a large hex pattern.
http://www.summitracing.com/parts/GOR-20633/
![Name: lugs.jpg
Size: 8.9 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/87967d1501791993-open-end-vs-closed-end-lock-lugs-lugs.jpg)
I received them today. They are not closed so rust may be a problem. They are a "lock" type in the sense that the key has it's own number so I assume there are many different keys available. Meaning, someone can't buy this kit and use the key on my kit.
If rust is a problem what's wrong with wiping silicone on the studs including the tip before mounting? Assuming the rust is from the studs and not the lugs. Currently I use an anti-seize on my lugs. That alone might work too. I think it would wear off the tip of each stud over time though.
Update: I had to remove one of my wheels a few weeks ago. They key is in really bad shape. No problems installing the lugs, but only after 5 lugs were removed, the key is so badly bent, that I don't think I'll be able to take off the rest of the lugs
. I've ordered a set of closed end lugs for next season.
Gorilla 20633 Hex Socket. I have six more lugs to go. Two huge scratches on my rims now from pulling the fucked up key from the lug. I have no other way to get it out. I'm taping up the rims now so I can get the key out without scratching. I'm also filing down the key because it's so bent, I cant get it in the lugs anymore.
Here's the first scratch:
![Name: IMG_3282.jpg
Size: 62.4 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/87970d1501791993-open-end-vs-closed-end-lock-lugs-img_3282.jpg)
This is how you remove these lugs. Remember, this is the first time I've removed them, 100 foot pounds.
![Name: IMG_3281.jpg
Size: 54.3 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/87971d1501791993-open-end-vs-closed-end-lock-lugs-img_3281.jpg)
And the third scratch. This was through three layers of tape:
I feel like a retard but holy shit, there is no way to get that lug off the only key I have. I guess I'm getting a fresh coat of clear this winter.
I run open lugs with the studs sticking through the nuts as required by the rules in the other car. No problems ever with rust. The fastener is overall stronger with threads sticking out past the nut 1.5 times it's diameter. This is part of the reason the NHRA requires open lugs. I've had them on the car for at least 10 years with zero problem. Not that it matters on a TL but at least you're getting some performance benefit out of them too even if it's never realized.
![Cool](https://acurazine.com/forums/images/icons/icon6.gif)
![](http://i27.photobucket.com/albums/c172/Mug13/Acura%20TL/Dynas/IMG_3282.jpg)
![](http://i27.photobucket.com/albums/c172/Mug13/Acura%20TL/Dynas/IMG_3281.jpg)
Why did you torque the locks so much?
That does not seem right,,
100ft/lbs?????
I did not look at the service manual but I would do them tight. Then another 2/10 oc a turn, then check them all again.
Your key probably got destroyed and twisted out of shape.
takin care of Business in
Received 4,732 Likes
torque specs for the stock lugs are 82 ft/lbs.....
I remember one time around I tightened the lugs tooo tight and when I went to take em out the stud got bent....and this is coz of too much force using a key....and i have closed end....
so yeah....dont tighten them too hard specially when using a key...
^^^ i dont wanna get flamed on this but my ex girls brother tightened my lug while i was working on the other rim....
he stood on the bar to tighten the lug...he is 180 lbs....
![what](https://acurazine.com/forums/images/smilies/what.gif)
For those with rust issues, buy higher quality lugs/studs. I've run ARP hardware all these years and never had rust issue and my studs stick out a good inch past the lugnuts.
As for torque, refer to the manual even when using aftermarket nuts. The torque requirement is determined by the stud, not the nut.
![Victory](https://acurazine.com/forums/images/smilies/victory.gif)
AZ Community Team
Received 7,770 Likes
FWIW, the Service Manual ('04) says 108 Nm or 80 lb-ft .... well, it actually says 79.6 lb-ft, but
The problem is when someone (Gorilla Larry at Billy-Bob's Tire, Lube & Down-Home Bar-b-Que) tighten's 'em way over the spec. Resulting in busted wheel locks, snapped studs and warped rotors, for example.
^^^ hahaha experienced that as well....
got my tires from this mexican dudes shop...150 for all 4 installed and balanced.....the guy used an impact on my wheel locks....snapped the metal inside the key....![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
well thanks for correcting me...I always go by 82 ft/lbs....good to know its 80 ft/lbs...I will double check it on my 05 (only coz u said FWIW LOL)...
AZ Community Team
No, no, I didn't mean to "correct" you - 80 lb-ft; 82 lb-ft, 2%, meh, no difference.
I meant to support you with the number from the SM; especially compared to 100lb-ft.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
swoosh (11-26-2011)
I had to take one of the company trucks to get new tires and watched the guy not only run them up with an impact without a torque limiter but he started them with the impact as well. It was a company vehicle so I stood there smiling but I have to wonder what goes through their heads to make them decide saving 5 seconds per lug is worth the potential stripping, warping, breaking, etc. I did that for a living when I was young and it took breaking one stud off and having to pull the axles out to repair it to break me of that habit.
(I have access to air tools, hoist, torque wrench, impact driver, etc everyday for free)
^^^ hahaha....
you bet...I stand in the bay while they do the work on my car and
WORK = rotation/balance/alignment...thats all...everything else I do in my car port![Ninja](https://acurazine.com/forums/images/smilies/ninja.gif)
but i completely agree with you IHC....barely takes 30 seconds more per lug....
the first time I went to Firestone, he actually hit the lugs with impact when i told him dude WTF....and he was like "I will finish off with a torque wrench"....i stood there looking at him like "really?"....since then he knew i was right in the bay everytime my car came thro....he does everything to my liking and i bring him lunch everytime i go there....win win situation![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
and yeah the chic who works there knows I take it to this technician ONLY....and she was nice enough to come by and give me her safety glasses....
rockyboy
12-06-2022 02:29 PM
DiamondJoeQuimby
09-10-2015 11:40 AM
ahsm
09-09-2015 08:35 AM
