Offset for flush look?
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/what-19-specs-will-give-you-flush-look-info-here-731898/
that was my thread.... depends if you have rolled fenders or stretched tires. If you want the flush look WITHOUT rubbing, you are going to have to stretch your tires.
According to my math, an 18x9 wheel needs a +16 offset to be flush. Might want to put a 215/40-18 tire on there.
https://acurazine.com/forums/showthread.php?t=731898
Utilizing the search feature here…
Will an 18x9 +38 with a 245/40/18 tire work without rolling the fenders? I’m on the A-Spec suspension. Also, is a 245 series tire too narrow for a 9 inch wide wheel? I don’t want to go with the “stretched” look or bump the tire size up to 255.
Off the top of my head, I don't know my camber settings. I currently have 18x8 A Spec wheels with 235/40/18 tires and have no issues. I'm ok with that wheel width/tire size combo and was assuming 9" wide wheels with a 245 tire would achieve a similar look and hopefuly not rub the fenders.
neuronbob
23
07-16-2019 10:48 AM
SinCityTLX
55
10-11-2015 01:20 AM
