What 19" specs will give you the flush look? Info here.
So many people are striving to achieve that "flush" look, by which the rim sits perfectly in line with the fender.. I created this thread to provide info on what specifications on 19" wheels will deliver that look, and pictures to go along with that information.
*This information is for the rear.
All of you should know that I have been through a myriad of different sets of wheels.. and from all, I have found that my Volk LE37T set up was the most flush. When the car is in the air, there IS poke, but without any camber kits (natural camber), the rear wheel sat flush, 2-4mm poke at most.
The specifications on the rear were the following:
F: 19x8.5 +22
R: 19x9.5 +22
Here are pics:
By simple math, I compared my set up to ballinfizzles, who had:
19x9.5 +32
19x10 +30
The difference was 2mm, which is close to nil.
Here are pics of his set up:
Now, these sizes (9.5 & 10) are very common sizes to run in the rear so those offsets will deliver flushness.
Comparatively, if you wanted to run an 8.5 and achieve a flush look, the specs would have to be:
19x8.5 +9
For a 9" width:
19x9 +16
For a 10.5" width:
19x10.5 +35
All this isn't phenomenal, it's just math. Happy wheel shopping!
F: 19x8.5 +22
R: 19x9.5 +22
Here are pics:
19x9.5 +32
19x10 +30
19x8.5 +9
For a 9" width:
19x9 +16
For a 10.5" width:
19x10.5 +35
The following 10 users liked this post by bforbrian:
2Morrow (07-23-2013),
General0341 (07-12-2013),
Glock20C (03-13-2013),
iodprod (12-08-2012),
michaelw21 (01-13-2012),
and 5 others liked this post.
Stand For Something
This might have been good information if you had taken into account the following issues:
Rubbing
Fender Rolling
Stretched Tires
With the specs you provided, rubbing will occur without the rear fenders rolled and/or if you do not have stretched tires. Seeing as tho the majority of people on here are not going to stretch a 225 tire on a 9.5" wheel or a 235 tire on a 10" wheel, and the majority of them do not/will not have their rear fenders rolled, this information is close to useless.
BUT, for the few who do have the fenders rolled and do not mind stretching tires beyond belief, nice thread
Rubbing
Fender Rolling
Stretched Tires
The following 2 users liked this post by ASASN21:
2Morrow (03-08-2013),
Phat_Type S (05-02-2013)
Rubbing
Fender Rolling
Stretched Tires
Rubbing
Fender Rolling
Stretched Tires
Me and ballinfizzle both have our fenders rolled and will be required to fit these spec wheels... Stretching of tires is a must as well; a 275/30-19 tire fits perfect for a 9.5 but that will look silly and rubbing will occur even if fenders are rolled with that size...
225 and 235 series tires are a must.
You can still run a 275/30R19 tire on a 10.5 wide rim with an offset between +40 & +43 of course you'd have to roll the rear fender and run a slight negative camber.
rear 19x10.5 wide rim +43 wheel offset & 275/30R19 tires below... lowered...
5th Gear
F: 19x8.5 +22
R: 19x9.5 +22
Here are pics:
19x9.5 +32
19x10 +30
19x8.5 +9
For a 9" width:
19x9 +16
For a 10.5" width:
19x10.5 +35
F: 19x8.5 +22
R: 19x9.5 +22
Here are pics:
19x9.5 +32
19x10 +30
19x8.5 +9
For a 9" width:
19x9 +16
For a 10.5" width:
19x10.5 +35
I like the rear window visor, Where do you finded? Is for the Acura TL or a modify one?
94 DC4 RS LSV/Turbo
this is a thread about being flush... NOT TIRES...
besides these are mild stretches, a 235 on a 10 aint that bad... now a 225 on a 10 is coocoo for coco puffs
I found that for the front, a 9.5" width +30 will be flush.
In terms of a 9" width, +24 would be the offset of choice.
Remember, this enables you to kiss the lip of the wheel with the edge of the fender. If you run tires that are flush with the wheels, YOU WILL RUB, lol.
With flushness, you will have to stretch tires.
Btw, my rear fenders are rolled and slightly flared out so give about ~3-4mm of more give if your fenders are stock when calculating the math. In other words, a 9.5" wide wheel on stock fenders should have roughly a +25 offset.
Registered Member
Legit question, he was asking for the front.
Brian, those Le37Ts you got.. sorry man new to this thing. Ive seen other LE37T''s and the spokes look flush like flat is you were to look at them like how your pics show, but your looks like there out going towards the hub, is it because of the offset? cuz thats what im looking for. pls help thanks...
A +22 offset will usually give you concavity (and less, volk makes +12 as well).
Yes, that would work, it's just math.
nice thread bump. Ok so I got 19x8.5 axis shine offset +35. Not sure if I wanna go for the "flush" look or not but thought about it. Got 15mm spacers up front and 20 in the back making final offsets +20 and +15. I am only 1.5" lowered all around with -2.3 degrees camber in the rear(no camber kit just natural camber from lowering the car). Rolling fenders is a must obviously but i was wondering if I was to go this route, what size tires would I need to get. Could I get away with 235/35 all around or would I have to go down to 225 or even 215?
This thread has been super helpful. Just got new set of wheels that are 19X9.5 with +25 all around wraped in 235-35's. I know the rears will be fine, but what issues if any will i have with the fronts? Also what size spacer for the rear to get it even more flush? (I have Megan Racing coilovers too. )
LIST/RAMEN/WING MAHSTA 짱
No, B. I said "speedometer", but it'll affect the odometer as well. If you get too far off of the stock tire size, the speedometer will either read too slow, or too fast.
If you care about an accurate speedometer reading, and you want 19's, I'd get 19x8.5's, and put 235/35's on them. 235/35/19's are very close to 235/45/17's in overall tire sidewall size. It'll keep your speedometer reading accurate.
Of course, this matters only if you care. If you don't, then any size will do, as long as you can get it to fit.
